Boost gauge install..help. Can't find the accessory power
Old Feb 14, 2012 | 06:53 PM
glamcem's Avatar
Unhappy Boost gauge install..help. Can't find the accessory power
I was looking at this thread
https://www.evolutionm.net/forums/ev...lean-hell.html
and searched few others but "fuse tap" solution doesn't work for me for some reason. I tried two different fuse taps but no power when it's connected to the accessory fuses..
Is there any other place that I can tap for accessory power? I have no problem with constant or ground connection since I can use my dome light for that(as I did for my radar detector)..
Any help would be highly appreciated.
Thanks
Old Feb 14, 2012 | 07:03 PM
galantman03's Avatar
in my car i used the cig lighter power, but IDK if evo x's have cig lighters
Old Feb 14, 2012 | 07:46 PM
glamcem's Avatar
I do have cig lighter but guys at Prosport told me not to use it since it's dimmable
Old Feb 14, 2012 | 08:06 PM
do you want constant power so that the gauge stores all of its presets? IE recall, peaks, ect? if yes then idk what gets constant power in the evo besides the batt itself, but if you don't need constant power, just tap into the 12v supply on the rheostat itself, cuz you have 3 wires, 12v, ground, and your "adjusted voltage" to dim the lights.
Old Feb 14, 2012 | 09:07 PM
glamcem's Avatar
thanks for all the inputs..I figured that out, the "add-a-fuse" requires two fuses instead of one, that's the problem I was experiencing
ZWingerRyRy
Evo X How Tos / Installations
267
Apr 22, 2020 04:26 AM
mrwickd123
11
Nov 2, 2016 10:19 PM
trinibt65
Apr 14, 2016 02:18 PM
chaotichoax
Jan 30, 2010 06:46 PM
ZWingerRyRy
32
Sep 10, 2009 07:51 AM
