Finally got rid of the factory sound system!
I finally got my dash kit, head unit, speakers, amps, and sub the other day. So I decided to install it. I went the Metra dash kit despite all the bad hype about it. Personally I'm happy with the way it fit. My head unit is a Clarion NX602. It's amazing, very user friendly , loads everything quickly, navi works great, and looks nice. My speakers are Helix Esprit E62C components in all doors. The sub for now is a DB drive K3 12D4. The amp for the speakers is a DB drive A4 4200 and the amp for the sub is a DB drive A4 1800D. The sound is amazing, the speakers are crisp, clear, bassy and soooo loud. The sub isn't bad for a lower end sub, good bass and gets pretty low. Here's some pics:
You had me until the trunk. You lost a ton of space back there that you didnt need to. And the amp is mounted on the top of the trunk, so cooling may be an issue.
Here is what I ended up with:
http://www.flickr.com/photos/13891619@N00/5782187973/http://www.flickr.com/photos/13891619@N00/5782187973/ by http://www.flickr.com/people/13891619@N00/, on Flickr
The most important thing is that you enjoy it though, and it definitely sounds like you are doing that.
Evo X Amp/Sub install by Brian, on Flickr
The sound quality is simply amazing. In my last car I had Focal PS 165's which are pretty bad *** speakers. These are just as good if not better as far as loudness and clarity. The tweeters in front and behind also makes a huge difference. Every little sound is picked up and heard.
Thats one of the two heads I am debating on getting... Its either the NX602 or the CZ702 (single din - but has time alignment and can be used to go active later if needed/wanted)
Head install looks good...
