Leveling Switch Wiring
Hey guys,
I have a 2011 Lancer GT (Canadian), just installed some EvoX HID headlights. I have the OEM leveling switch, which plugs in at the dash. However, the wiring is not present at the headlights. I notice some people have it on the main headlight connector, however they are blank on mine.
Now, I figure this headlight harness must run back to a controller to perform it's functions. I have no idea what it's called (I've seen ATACS been thrown around)
Anyway, I figure if I can run back to this controller, I can match the pins up and run the wiring from the controller to each leveling motor. Problem is, I have no idea of where this controller is located, or what the pinout is.
Does anyone have any info on this, any pinout info or even the location of it? I'd really like to get the leveling feature, as I ordered the switch. Anything is appreciated! Thank in advance!
Hodder
Hodder
Hey guys. Getting back at this again, working a lot lately so I only get at it a bit at a time.
Here's my problem a litter more concise. Picked up some Evo Lights, along with the OEM leveling switch. I have the wiring at the black switch panel for the switch to plug into. However, I don't have the wiring at the headlights for the motors. It seems that most people who have the wiring at the switch have it at the motor, but I guess I'm not that lucky.
Anyways, I searched up the circuit diagrams for the leveling circuit. Sorry they're a little large, just make it easier to see.
There's only 3 wires that are involvedin the leveling circuit. One for the Motor Drive, one for Voltage Comparison, and one for Ground. Ground is easy enough, but the other two are where it gets tricky. However, according to the first diagram, I should be able to get the wire for the "Motor Drive Circuit" on Pin 5 of C-130, and the one for the "Voltage Comparison Circuit" on Pin 3 of C-131. Where these connectors are, I have no idea. Do any of you guys know? I wasn't able to find a diagram showing the placement of the connectors around the car. Any help on this would be much appreciated !
It's a pretty specialized problem. Like I said, most of you guys who have the wiring at the blank switch panel for the leveling switch generally have the wiring at the headlight, which makes it pure plug and play. Could be worse I guess, I could be missing the wiring between the switch and ETACs.
.DoT.
Today 08:55 AM
