Audio Aux?
Old Dec 9, 2012 | 06:38 PM
CrossRifles's Avatar
Audio Aux?
I have a '12 MR without an Audio Aux. I was surprised when I found out it didn't come with one. I know where it should be, but when I take out the black plastic square under the temp controls, it's empty. I do however have a USB port in the passenger side glove box compartment.
Question is, can I just install an Audio Aux port in the OEM position? Or would I have to get a new radio with an Aux port?
The USB bugs the hell out of me as it takes forever to start up and like a good 10 seconds to change songs. I know this sounds trivial, but it's the little things that get to me.
Old Dec 11, 2012 | 02:58 PM
ayOitztuan's Avatar
I thought the AUX outlet was underneath the navigation, like when you press the open button to put in the CD its on the underside of the screen, am I wrong? LOL, never used it.
Old Dec 11, 2012 | 04:19 PM
I have no Navi. Only basic dash radio. I think you're right for people who do have Navi, but for basic non-Navi models, it should be directly under the A/C controls behind a black plastic square flip door.
Old Dec 17, 2012 | 01:37 AM
Risktaker's Avatar
I have a GSR with the same issue. I *read* that it is just plug and play, but I haven't done it yet.
So yeah, basically my response here is worthless but I just wanted to be subscribed to this thread and also to ask you to report back if you get a definitive answer.
Old Dec 23, 2012 | 08:57 PM
CainEvoX's Avatar
I just read on another thread that all lancers 11 and newer had the fuse thing that allows you to stream via blue tooth. might be worth looking into
Posted from Evolutionm.net App for Android
Old Dec 23, 2012 | 11:32 PM
I have that standard in my MR. The BlueTooth stream quality is bad. Noticeable static can be heard.
Old Dec 24, 2012 | 07:19 AM
ZeroX's Avatar
from what ive seen '11+ have the fuse system and the usb port in the glove box. not a big fan of the fuse system either.
Old Jan 12, 2013 | 09:08 PM
amejde01's Avatar
aux
i have the 2013 MR base no nav no satelite. fuse and usb only. just in case you have yet to figure it out, yes you can just buy the aux inputs from the dealer and the wire exists right around the area where the inputs mount to. mine does not even come with the harness for sirius sat. but bluetooth on my fuse works really really great.
Old Jan 13, 2013 | 05:29 PM
WWkevoX's Avatar
in the cubby under ac control behind that plastic tab you should have the white and red plugs that are used for the aux. Have to buy a red/white to headphone wire for aux. but i don't use it anymore, have an ipod plugged permanently in my glove box to the usb connection
WC3322
28
Oct 7, 2023 11:44 PM
Shirish Agarwal
Sep 19, 2012 01:38 PM
jestoy7
Feb 2, 2012 05:26 AM
Evo209Viii
Oct 17, 2011 10:41 PM
kadykady
10
Aug 23, 2010 03:36 PM
