Audio Upgrade Questions
So I am new to the Evo community (long time fanboy) and just purchased a 2013 MR
. My question is, the car came with the base crappy radio. Not even the Rockford system. I have a friend who has a 2010 Nav/touch screen unit and stock sub out of his touring model.
Is it an easy swap or am I going to need multiple conversion parts. He is giving me a great deal since he upgraded to all aftermarket.
. My question is, the car came with the base crappy radio. Not even the Rockford system. I have a friend who has a 2010 Nav/touch screen unit and stock sub out of his touring model. Is it an easy swap or am I going to need multiple conversion parts. He is giving me a great deal since he upgraded to all aftermarket.
For this to work you would need -
Nav install kit (correct adaptor harnesses, gps antenna, ect.
all wiring for the factory amplifier (and you have to run the harnesses) ((this harness contains all connections. power, signal in/out, everything. it runs throughout the entire car. be prepared to strip the interior and run new wire into the doors to do this correctly))
change all standard door speakers to factory fosgate speakers (stock non-rockford wont work with factory rockford amp)
and then after all that effort you still have a pretty ****ty stereo. (my '14 MR came with rockford...its meh at best.
Just go aftermarket. Way less hassle with better end results. if you have questions, ask away.
I would for sure pass on the factory equipment.
You really dont have to spend much to get bluetooth + better sound. A lower end but still quality head unit and a set of front components will do wonders.
A lower cost head unit i like alot (and always get great results from) - http://www.crutchfield.com/p_113DDX3....html?tp=20217
Great sound at a lower price point - http://www.jlaudio.com/c2-650-car-au...-systems-99617
Going with those ^ will get you much better sound and functionality than the factory system ever could. Questions?
2006blkevo9
Apr 20, 2009 07:48 PM
Q8_EVO
37
Mar 1, 2007 03:29 AM
jennz03
21
Mar 14, 2005 10:51 PM
mdacko
Sep 1, 2004 10:11 AM
