2015 Evo X sub and amp install help
Old Jun 5, 2017 | 10:43 AM
Christianlimon's Avatar
So I was wondering if anyone has happened to installed an aftermarket amp into your evo x. I was wondering if anyone knows were you can get the wires for the rca convertor. I do not have the Rockford fosgate edition and the battery is in the trunk can anyone help me?
Old Jun 12, 2017 | 08:14 AM
bolothedv's Avatar
I believe what you're referring to is a line out converter. Converting an existing 2 channel speaker wire in to an RCA to use for an amp. Something like this is what you're looking for:
https://www.walmart.com/ip/Scosche-L...&wl13=&veh=sem
Ebay, amazon, crutchfield.
Old Jun 13, 2017 | 02:39 AM
yes i I have that and I have my amp connect and wired to the battery all I need now is to find a power source for the speaker and that convertor you sent but where would that be located that is my current issue
Old Jun 13, 2017 | 08:12 AM
bolothedv's Avatar
So this device allows you to change one speaker's wiring from the factory to a 2 channel RCA. Not sure about your set up, but I've always had two amps: one for my sub and one for my other speakers. so you would power the factory speakers from the amp.
If that line converter requires a power source, could you not use the amp power source?
Old Jun 13, 2017 | 09:31 AM
splattj's Avatar
You get a line-level converter and you can just grab the connection at your rear speakers for signal. Then you hardwire the converter and the amp to your battery. Hook the remote power-on wire from the converter to the amp. And then, when the car is on/the stereo is on, it will power-up the sub amplifier and use the speaker signal to provide a line-level output/input for the sub.
Christianlimon
Jun 5, 2017 06:34 PM
Firebat
Evo X How Tos / Installations
Nov 29, 2016 06:49 AM
Topdown
Northwest Region
Aug 20, 2012 03:35 PM
Wicked CAS
Evo 'For Sale' Electronics / Lighting / Audio
76
Apr 12, 2011 06:50 AM
