Rewiring stock audio harness
Old Jul 25, 2025 | 09:24 AM
MrGabs's Avatar
Greeting all,
I recently bought my dream car (Evo 8 GSR) and will sliwly, but surely, start making it my own. As part of it, I am changing the radio and speakers to some double DIN.
My situation is the following: I'd like to rewire the harness to make it as stock as possible in order to have a good baseline to go to in the future.
Below in the pictures, you will see a lot of connection and such. I plan on soldering once the new radio comes in.
My questions are the following:
1. Which adapter (big ones) is the vehicle's stock one? I'm assuming white one.
2. It's my assumption they used the white adapter for 12v power, accessory and memory (since some of the gauges are also tapped into them) and then spliced out the speakers, tweeters cables. Is this correct or good assumption?
3. What would be the best way to rewire back to the original (closest to) harness?
4. Any suggestions or ideas are definitely welcomed.
See pics for reference.
How I found the radio harness after uninstalling.
Better view of radio harness and cabling.
Old Oct 1, 2025 | 05:21 AM
absuil's Avatar
I'm trying to install a new system today.
Old Oct 18, 2025 | 08:36 AM
mery's Avatar
I eliminate the OEM harness altogether, and hard wire everything, fresh 12 volt battery, 12volt ignition, and all fresh OFC everything, including speaker wire, since the factory wires run thru much much to many junctions, which degrade sound I have also learned if you do use the OEM harness, It affects the idle of the car on some models Mitsubishi to name 1,it was like the cars ECU didnt like it, idle.
lord251
Dec 29, 2010 04:42 PM
fatalbert69
Feb 9, 2005 09:03 AM
darkturbo
Feb 4, 2004 07:58 AM
