How long to hack the X ecu?
I would like some of those in the know to discuss how long they think it will be before we can start tuning the X's stock ecu and if anyone has started trying.
I am going to hopefully start to see if we cant get the ROM off our Evo and then send it to Tephra and JSCbanks so they can try and disassemble it. I am sure that we can get it done.
Mitch
Mitch
tephra said with getting the rom, disasm, and making definitions it would probably be 6 months for something like ECUflash to work with it. I am not sure if he was being facetious though.
I think someone should rename this one, how to void your warranty by hacking your EVO's ecu.
joking. I already heard break thrus in Japan with tuning, but dont know the name of the group doing that
i will ask around
i will ask around
And look how long it took to get the Evo ECU support that it has today. And that is on a protocol that has been around for what, 10 years? I have a feeling it is going to be a while before the X ECU can really take off.
Cobb tuning has already been on top of this, even before the car came out
http://blogs.cobbtuning.com/?p=46
Last I heard, the VW guys were still having trouble with tuning for the R32 transmission ... the Evo X MR transmission is very similar, so you can expect that to be quite a battle for tuning.
I heard that the system is on a CanOpen bus, which is an open protocol with a standards body. I sell a lot of industrial automation equipment that uses CanOpen, and we can probably find some protocol analyzers etc to see whats going on as far as the communications goes. Might also be able to add some neat devices onto the bus to do some fancy stuff (think flashing lights, etc...).
If anyone in their line of work uses Allen Bradley and DeviceNet...DeviceNet is a subset of CanOpen.
I've heard that some of the tuners are going back to the HKS F-Con VPro, and have had good luck with that so far. The ECU flashing seems to be a long, painstaking process as of now, but I'm sure the results will pay off.
Jerry
Jerry
