Wideband o2
Old May 10, 2008 | 11:26 PM
Talon_66's Avatar
Wideband o2
I have a few questions regarding my AEM Uego Wideband.
This is the first wideband Ive owned so I do not know if this is normal behaviour for a wideband.
First, when I installed it I also installed a boost gauge so I connected both gauge's power wire together, and connected it to a 12v source.
Second, maintaining a steady speed, is it normal for the wideband to read from (for example) 14.5-15.3 and traveling this much?
I also noticed at idle, it reads 12.9-13.0 for about 40 seconds then the afr raises to about 15.
Old May 11, 2008 | 11:22 AM
Mightygnu's Avatar
You aren't tuned yet I am assuming!
Old May 11, 2008 | 12:54 PM
Talon_66's Avatar
Nope not tuned...
Another question...
My boost gauge, under light driving only hits 10psi.
but under heavy driving (WOT) it will read 21.
normal also?
Old May 11, 2008 | 01:43 PM
J5isalive2's Avatar
yup everything sounds normal...the wideband will move quite a bit when just crusing along, but it will remain within 1 full point usually.
Old May 11, 2008 | 01:52 PM
EvoBroMA's Avatar
sounds perfectly normal. it bounces around and cruise and idle because the car is running off a narrow band which oscillates around stoich. (14.7)
Old May 11, 2008 | 02:48 PM
Talon_66's Avatar
Sounds great, thanks. Im a newbie when it comes to Turbocharged vehicles and widebands
Old May 12, 2008 | 07:34 AM
psy-q's Avatar
My Eclipse is the same way. If you actually log the narrowband O2 sensors you'll see why the ECU is up and down. Those things bounce all over the place.
Old May 12, 2008 | 10:21 AM
Mightygnu's Avatar
For being a newbie, thats quite a mod list you have in your signature.
Old May 12, 2008 | 10:36 AM
Jooyoung99's Avatar
Nope not tuned...
Another question...
normal also?
Mine use to hit 23 psi, but after all the mods (FMIC, Pipes, Turboback), it dropped 2 psi.
Old May 12, 2008 | 01:07 PM
Talon_66's Avatar
Thank you
Im not a newbie to modifying, just to turbocharged vehicles.
At WOT my AFR is 11:1
kyoo
Jun 30, 2019 12:44 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
mister1161
Feb 20, 2016 03:51 AM
EvilEvolution8
Dec 11, 2015 01:51 PM
spyderx
14
Nov 24, 2006 08:08 AM
