Question to tuners - is this possible?
I'm curious if the following is possible and correct me if my understanding is wrong or misinformed.
- while idling or cruising lets call it highway driving, the ecu uses the stock a/f, boost, etc maps.
- while driving hard lets call it track driving (if you have done a reflash ie: bushur, ams, etc) it goes to the modded maps
Is it possible then to tune an evo for both occasions using the same ecu since the maps aren't used at the same time? ie: leaner for better mileage on the highway and a bit richer for the increased boost, etc that is used during "track driving"?
Just curious. Thanks,
In this mode the ecu adjusts the long term and short term fuel trims based upon the feed back of the front 02 sesnor to achieve a ideal a/f ratio of 14.7 at all times
When the car transitions to more load the car will switch to open loop operation where there is no feed back loop
A tuner will adjust the cross over point and open loop operation mode. Also the car will be trimed to minimize any corrections in closed loop mode to get the car close to a 0 (zero) correction.
However, the ideal a/f ratio target is not generally modfied as this is a law of physics not a tuneable parameter. It is possible to adjust the actual desired a/f target on closed loop the ecu looks for in many reflash programs, however, this is not generally something I adjust.
I hope this makes sense - if not feel free to follow up.
No sweat man. There is a really simple reason why the Evo guzzles gas. It needs a sixth gear! Fifth gear is a .87 gear going through a 4.53 final drive ratio. I don't know what the speed limit is in your part of the country, but this means that the car is turning just over 3700rpm at 80mph. That coupled in with the fact it weighs 3500 pounds is definitely why is gets crappy fuel economy.
Realize that for 2008 models, companies were all forced to change the way they show fuel consumption per mandate. So that had an effect on it too. Using cruise control and exercising restraint when commuting will go a much longer way for your fuel economy than leaning the heck out of the mixture IMO.
Good luck, and I hope you end up with an Evo.
Later, Ken
Noize,
I appreciate the responses. Unfortunately no Evo X yet, mainly trying to do some research and the engineer in me keeps wondering why the evo guzzles the gas. I've been reading up on stoich, A/F, proper mixtures, etc prior to posting and what made me think of this was reading the Evo tuning for Noobs guide in the Ecuflash forum. In there I believe the author said the highest mileage came around 15:1 or somewhere around there. A lot of it would be very dependent on quality of gas, weather conditions, driving habits, etc as you already pointed out. I'm sure a good tuner could come up with an excellent map and / or compromise to the solution. Thanks again for the helpful info.
So the first step, if you want to run 15.2-15.4:1, is to get rid of the stock cat. You replace it with a test pipe.
The second step is to get yourself a wideband that simulates a narrowband sensor and get it installed. Then you disconnect the wire that sends the signal from the ECU to the stock O2 sensor. That signal keeps the car running at 14.7:1 in cruise and idle. Keep the heater O2 sensor signal connected so you will not get a CEL.
The third step is to take a wire from the analog out of your wideband and connect/tap into the wire that goes straight into the O2 sensor.
Finally, you can program your wideband to send a signal to the stock O2 sensor to allow the car to run at 15.2-15.4:1 at idle or cruise.
You are basically by-passing the stock O2 sensor and allowing your wideband to simulate a narrowband O2 sensor. Your are tricking the ECU into allowing your car to run at 15.2-15.4:1
This process should net you an improved mileage of about 2-3 mpg.
This is the most common way used to tune for mpg at cruise and idle.
Some have tried tuning the cruise/idle fuel map for better mpg, but the results have been mixed.
I have tried both ways and found the former to be more consistent.
Noize, While it is true, weight and high rev at highway cruizing all adds to low mileage but I also think the OEM injector size (660 cc/min) are a very significant cause for the gas consumption in the X. The OEM 4G63 (eclipse/talon/laserGen1) was rated at 195hp and I got ~27-28 mpg on highway. The X is rated at 295 hp. So how did the X achieve the 100hp? Answer: bigger injectors (440cc/min in 4G63), more aggresive cams and bigger turbo, etc. The Gen1 elipses' were lighter but I think that the weight was less of a factor than lower performance parts.
Later, Ken
Later, Ken
I can't agree with you. First of all, injector size has nothing to do with fuel economy if a car is mapped properly. My Evo VIII got the best fuel economy when it had 680cc injectors and a big turbo. Bigger injectors have greater flow potential when needed, but don't get worse fuel economy on the highway cruising.
Second, check this out: http://www.turbomagazine.com/tech/08..._manifold.html They claim that they pulled the engine and found that it uses 540cc injectors. This would help support why I am seeing nearly 90% IDCs at very high RPM. But injector size doesn't really have anything to do with the final point below.
The 1G Eclipse and 2G Eclipse had an even taller fifth gear than the Evo VIII which is taller than the IX, and the X has the same 5th as the IX with a shorter final drive. The gearing and lack of weight are why the older cars get the best fuel economy.
REPEAT AFTER ME: THE ONLY REASON OEM'S TARGET A CYCLING AFR AROUND STOICH IS FOR PROPER OPERATION OF THE CATALYTIC CONVERTER!
The converter stores oxygen while lean, then uses it when rich, in a cycle.
There is NO other reason for it.
There were, and are, special lean burn vehicles that used special converters that stoich means squat.
Where do y'all think wideband sensors came from? LEAN BURN VEHICLES!
The cat and warranty is also probably one of the main reasons its fueled so rich in open loop.
I can't really disagree with someone like you or Naji going half a point leaner than stoich at cruise. I do think 16.8 as mentioned earlier in the thread is very excessive.
Lots of people in my area run cats due to the type of emissions tests we have and the ramifications if you were to get caught without one. Others just care about the environment and don't want to run a test pipe.
16.8 is not excessive. I believe a new Honda engine runs at 22:1 during cruise. I ran 17.5 on my Evo 8 during cruise with no problems. During cruise there is very little load, so a lean mixture has no ill effects.
Check this out. Scroll down some for info on the Honda engines.
http://en.wikipedia.org/wiki/Lean_burn
Are you running your Evo that lean at cruise with a cat?
Coming clean, I fried a catalyst on an NA Mazda RX-8 Renesis engine. Those cars get just horrible fuel ecomomy. Granted, they have hotter EGTs than piston engines, but they don't take too kindly to being leaned out much, even a little at cruise. It didn't happen right away, but I believe the custom tune contributed to it over time.
I'm not set leaner than stoich in my X. I have hypermiled it and sustained 27.5mpg on the interstate. I can also drive like a head case and see 19mpg on the interstate.
Carbureted Japanese cars were running much leaner than that in the late 70's/early 80's.
CVCC anybody?
Stratified charge?
They got away with it because they didn't need a catalyst to meet 48 state emissions.
Wake up people, its all been done before.
CVCC anybody?
Stratified charge?
Man I haven't spoken too you in years, good to see ya!
What does everyone think is the safest lean cruise to run with the cat? would 15.7:1 be acceptable and possibly gain 1-2mpg?
Ken,
Additionally, if raising A/F ratio using a CAT increases mileage by 1-2 mpg (as per above posts), it does not seem worth the effort. So going down your road of either reducing vehicle weight and lowering engine rpm in 5th gear, I wonder how much one would have to lose in weight and what reductrion in gear ratio would be needed to get a significant increase in mileage, say at least 5 mpg? Your thoughts? What is interesting is we probably wouldn't even have these discussions/considerations if gas was <$3/gal or we were all very rich!!
Later, Ken
germanracing
Mitsubishi TC-SST Discussion
18
Jul 26, 2011 11:31 AM
