test pipe...cel..!!
Old Aug 9, 2008 | 02:23 PM
element2zz's Avatar
test pipe...cel..!!
so i just put on my test pipe, with defouler and additional spacer....
threw a cel right away....
WTF any ideas??
Old Aug 9, 2008 | 02:35 PM
Protostar1's Avatar
First make sure its actually a cat inefficency code...
Old Aug 9, 2008 | 04:04 PM
gotrnet's Avatar
yea the cat code takes a while to actually throw the code. it is one of the last things the ecu tests.
Old Aug 9, 2008 | 05:39 PM
goevox's Avatar
02 sensor could be messed up if it threw a cel right away.
Old Aug 9, 2008 | 06:16 PM
element2zz's Avatar
well it didnt throw it right away, maybe like after driving 20 minutes....
i know its a cat code...
Old Aug 9, 2008 | 06:24 PM
proracer718's Avatar
Were you able to check it? I thought the same when I installed my DP and TP and the problem turned out to be the MAF sensor. So you can never be to sure about the problem until you check it.
Old Aug 9, 2008 | 06:28 PM
element2zz's Avatar
checked it earlier today....
and it is a cat code..
any one with test pipes here throwing codes??
Old Aug 10, 2008 | 03:41 PM
Maxmumboom's Avatar
I had the same problem. I had MUFLEX make a test pipe for me here i NJ. I installed it when i got home and threw and 02 code. I installed 1 antifouler plug and still threw a code. I installed a second anti fouler and still threw a code. After installing 3 anti-fouler plugs, it had gone away.
MODS are: CAI, Test Pipe, Greddy TIC and an IVEY TUNE @ 10am tomorrow
Old Aug 10, 2008 | 06:17 PM
Protostar1's Avatar
I just put in the non fouler cel fix about 2 hours ago. I cleared the code and drove around for a while. I made it about 4 blocks the last time I cleared the code and before the fix. I made a lap of my town about 5 times as far as before and no code. Not to be a jerk... but you did do the cel fix correctly with the only one fouler drilled out and what not?
Old Aug 11, 2008 | 09:44 AM
Maxmumboom's Avatar
Huh. Did the anti fouler fix the problem. Your post ended in a bunch of run on sentences that made no sense to me. Could you please explain what you were trying to convey.
Old Jan 2, 2009 | 02:21 AM
element2zz's Avatar
Originally Posted by maxmumboom
huh. Did the anti fouler fix the problem. Your post ended in a bunch of run on sentences that made no sense to me. Could you please explain what you were trying to convey.
lol please do no insult my writing, i'm looking at yours and you ask a question but you type a period (.) instead of a question mark. Thats more confusing then my run on sentences.
Let me make this more clear since you dont understand.
I installed a test pipe, i installed the defouler (one drilled out and screwed into the other that is not drilled out) still throwing code.
Im going to try to install another defouler like maxmumboom and see what happends
Old Jan 2, 2009 | 11:28 AM
EvoX_SA's Avatar
what test pipe do you have? I have the UR test pipe and have never thrown a code.
Old Jan 2, 2009 | 11:53 AM
Red Dragon's Avatar
http://cgi.ebay.ca/TF-CEL-fix-O2-sen...1%7C240%3A1318
check them out.
What kind of test pipe do you have?
Old Jan 2, 2009 | 06:22 PM
SpeedI2acerX's Avatar
^+1 i have the same thing. works well
smanders
May 16, 2016 08:40 PM
Rguy
58
Jan 9, 2013 10:13 AM
Kanweezy
11
May 10, 2012 11:43 PM
dannyz
31
Oct 18, 2010 07:20 AM
ibarkovic
19
Oct 22, 2008 10:28 PM
