Best High Flow Cat option?
Old Nov 23, 2008 | 06:48 PM
Rguy's Avatar
Are any of you running one without a CEL? I dont want to pay the extra cost for a HFC and then get the same CEL's i would get from a test pipe. I want to be able to throw in a 3" HFC and never worry about it again.
Anyone having any success with a good reasonably priced HFC?
Old Nov 23, 2008 | 08:19 PM
tomatoEVO's Avatar
i have a cobb high flow cat and a CEL has been on for about 3 days now. i'm 'hoping' it's because i need an oil change, but if it isn't then i'll be pretty blown.
so hold off on cobb for now
Old Nov 23, 2008 | 08:27 PM
Talon_66's Avatar
I believe Ultimate Racing has a fix for the CEL on there High flow Test pipes.
Old Nov 23, 2008 | 09:05 PM
Rguy's Avatar
Yeah but i think its just a spacer and the CELs come around every so often.
Old Nov 23, 2008 | 09:29 PM
LVSBB6's Avatar
If you are on a budget, UR has pretty good review so far.
If you are willing to spend a little more money, go with HKS, Sard or Garage G Force high flow cat.
Old Nov 23, 2008 | 10:50 PM
tomatoEVO's Avatar
cusco makes one? hmm, i learn something new everyday lol
Old Nov 23, 2008 | 10:58 PM
LVSBB6's Avatar
i meant to say Sard...bummer lol
Old Nov 23, 2008 | 11:41 PM
BigmikeOC's Avatar
I've had the UR racing test-pipe on for about 6K miles, no CELs. Not even once.
Old Nov 23, 2008 | 11:45 PM
JoeyM3's Avatar
just installed a ur hfc metal substrate with o2 fouler, drove it for 100 miles and no CEL so far.
Old Nov 24, 2008 | 06:39 AM
tomatoEVO's Avatar
oh lol, ok
Old Nov 24, 2008 | 06:49 AM
binky's Avatar
I have a COBB high flow cat, with no issues at all. Put at least 4,000 miles on it.
-Bink
Old Nov 24, 2008 | 08:50 AM
KPerez's Avatar
Hey Bink, Did you do any before and after comparo's? If so, what were the results?
Later, Ken
Old Nov 24, 2008 | 09:04 AM
binky's Avatar
Later, Ken
Hey Ken-
I have an Apexi 3" turbo back exhaust. I was using the stock cat with Apexi downpipe / catback for a while. Once I put the COBB high flow cat on, there was a noticeable difference in how the exhaust sounded as well as noticing that the car pulled harder up to red line with the new cat.
I choose the COBB cat for a few reasons. First, it IMO it looks the best out of other companies cats (no weird heat shields / huge catalyst housing). Second, the catalyst itself only takes up a small portion of the pipe and the pipe itself is actually bigger where the catalyst is located.
If you are asking whether I had the car dyno'ed before or after, or if I ran it down the strip to compare, I did not do that. But I can say it mellowed out the sound of the exahust, I don't get a CEL and haven't had any issues.
-Bink
Old Nov 24, 2008 | 09:23 AM
Messidona's Avatar
Would putting on Test pipe result in boost spiking? I am considering putting on a CBE and a test pipe?
Old Nov 24, 2008 | 09:47 AM
KPerez's Avatar
Originally Posted by binky
Hey Ken-
-Bink
Thanks Bink. It will be interesting to see for you and others that use larger CAT's but still OEM internals will or will not pass emissions. I had to go "under the table" to get my old DSM to pass probably due to 272 HKS cams. I do not want to go through that again so it would be nice to get a less restrictive CAT but still pass emmisions.
Later, Ken
