R-VIT DS Data Link Station
Old Oct 7, 2008 | 10:59 PM
shazad's Avatar
http://www.blitz-uk.co.uk/ProductItem-2432.aspx
looks bad *** i wonder when they will come out with usdm compatible
Old Oct 11, 2008 | 03:36 PM
Xcited's Avatar
They are. I own one. It works awesome. I have it hooked up to a pioneer avic d3.
Old Oct 11, 2008 | 04:30 PM
coolarrow's Avatar
that looks pretty cool.....zeitronix has a DashDAQ display that could be similar.
Old Oct 13, 2008 | 06:31 PM
earthman's Avatar
does it read boost from the ecu or external sensor.
Old Oct 13, 2008 | 06:49 PM
ghoney81's Avatar
where can i get one??
Old Oct 13, 2008 | 06:56 PM
SiC's Avatar
SiC
I know you can hook up a Blitz WB to read AFRs but can you hook up like an AEM WB? Also does anyone know if this can show/log knock count & knock timing retard?
Old Oct 13, 2008 | 07:02 PM
ghoney81's Avatar
nevermind, i found one...
http://www.japanparts.com/db/partsli...21&volkey=135-
it does not include boost sensor.. it probably reads boost from the factory sensor.
"Monitoring for Speed, r.p.m, Water temperature, Oil temperature, Boost pressure, Intake manifold pressure and so forth. Monitoring by the Navigation system. If you want to see the Oil temperature or pressure, you need Temp sensor set(135-071-002) and Press sensor set(135-071-003). If you want to check the ATF situation you need A/F box(135-071-004) Also, Video input harness is available for RX-8 telematics(135-071-006). Remote controller (135-071-006) include. Only for Before M/C."
xceler8rob
Oct 17, 2015 04:23 PM
jcsbanks
Jul 13, 2009 09:59 PM
boy36
16
Apr 5, 2008 09:07 AM
Celm
Dec 2, 2002 11:05 AM
Dr.Evo
Apr 23, 2002 05:16 AM
