Cel
Old Oct 5, 2008 | 03:40 PM
08_XXX's Avatar
Cel
need help codes are P0102 and P0131
Old Oct 5, 2008 | 04:06 PM
EVIL_EVO_VIII's Avatar
PO102=mass air flow(MAF)
PO131=o2 sensor
Have you added any modifications to the car?
Old Oct 5, 2008 | 04:38 PM
JWA's Avatar
JWA
For future reference: http://www.obd-codes.com/trouble_codes/
Old Oct 5, 2008 | 05:54 PM
08_XXX's Avatar
hks drop in
Old Oct 5, 2008 | 06:25 PM
evo_Eks's Avatar
is your car idling fine? my car is in service for p0102. it's idling @2k+rpm. they said i have a busted maf sensor. i also have a hks drop in.
Old Oct 5, 2008 | 06:33 PM
TTP Engineering's Avatar
If you touch the maf wire inside the intake or install it improperly, it could cause issues.
Old Oct 6, 2008 | 12:06 AM
08_XXX's Avatar
no its idling @ 2k or so how long is it going to take to get ur car out
Old Oct 6, 2008 | 05:20 AM
SiC's Avatar
SiC
Since you already pulled the code, try and clear the code.
Idling @ 2k usually means its in limp mode.
Disconnect the battery for a few minutes and reconnect it.
Old Oct 6, 2008 | 08:21 PM
evo_Eks's Avatar
i tried disconnectin battery but didnt solve the problem. they ordered a new maf sensor so ill get it back as soon as they get the part. the amazing thing is they didnt care about my mods(drop in,uic pipe, catback). if you dont want to go to a dealership you can buy a rebuilt maf sensor through autozone. or you can follow this link
http://www.rockauto.com/catalog/rafr...=FR501-7450046
Old Oct 9, 2008 | 09:02 AM
steinvb12's Avatar
Sounds like limp mode.
I have the HKS drop-in and I don't have any codes or issues.
Old Oct 14, 2008 | 01:30 PM
Mojito's Avatar
It's bad MAF sensor. I've just had this code and sam symptoms. Clearing code didn't help. Turned out to ba bad MAF sensor.
It appears to be a common problem for Evo X
Old Oct 14, 2008 | 09:00 PM
08_XXX's Avatar
Smile
Yeah I got it fixed last week with no problem
Old Oct 14, 2008 | 09:22 PM
love9sick's Avatar
I have EXACTLY the same mods by my MAF is fine thus far. No codes.
If my MAF busts I wonder if they will deny me a new one if I have my mods and a tune?
Old Oct 15, 2008 | 07:17 AM
evo_Eks's Avatar
i have a base flash as well but the dealership i went to didnt even care so free it was!
Old Oct 15, 2008 | 11:47 AM
PlayinWithFire's Avatar
most likely since your aftermarket parts could easily be deemed the culprit. However, if they don't know you are modified... throw the stock intake and go in. It's a little sketchy on your part, but I know of a few people who do that when warranty-able issues come up.
