Problem With the MR please help.
Old Dec 1, 2008 | 07:11 PM
Besso's Avatar
"If you set your EBC to 21-22psi .. and lower the gain you should be fine .."
Old Dec 5, 2008 | 05:43 PM
philamthebest's Avatar
i set the psi lower, and now the car jolts.... si this the computer correcting itself and preventing itself from overboosting?
Old Dec 6, 2008 | 03:49 AM
gunzo's Avatar
define jolt..
During accelerating ?
shifting gear?
accelerate and then release pedal ?
harsh shifting ?
Old Dec 6, 2008 | 10:26 AM
Start of accelaration, foot down and then chug chug chug... the intake is making the nrmal swosh noise but then it cuts down and swoshs angain and repeats until you hit around 22 psi. The engine isnt chuging it's the intake and the turbo by what i can hear.
Old Dec 7, 2008 | 02:14 AM
gunzo's Avatar
surge, cut and go repeatedly ??
Are you in MAN mode or AUT mode ??
What is your gain ??
I would say this only happens in AUT mode as it tries to adjust boost response to get to your targetted boost the fastest way possible ..
It'll disappear once it decides it's learnt enough
If you're not in auto .. sorry can't help you .. limiter happens at higher boost .. not lower .. unless you're boosting so fast that you exceed the limits at lower rpms
Not easy to exceed the limits though .. unless you can get 26psi at 2400rpms
Old Dec 7, 2008 | 07:32 AM
your right it is ony in auto mode.... i will give it a while before i worry and see if it learns... What do you think? Is it normal for the intake to make that noise? do you now what i should set my gain to if i want to boost at 24 psi?
