EcuTek and Z chip compared on the same dyno
JDMEvo9RS- oviously from myself also "lurking around" TTP "rocks your socks" and are "the best tuners in galaxy" 1 turbo from a zchip owner is already gone, what i did was offer a test car so turbos blowing wouldnt happen. I would sometimes maybe remind them and talked good about them because "100whp" seemed so good for oviously the ammount they claimed. I dont want to start anything with you but think before posting stupidity. sorry for the offtopic, but i guess lets keep this for dyno sheets and/or scheduling a dyno day, i am eager to see the results, you never know the zchip can impress us, you never know
What alot of people do not understand is that one form of ECM tuning software or product, be it a piggy back, or full standalone, is not going ot make any more HP over the other in itself. The real factor is the person doing the tuning and the quality and combination of mods that will make the power difference.
The only difference in the actual units used to tune the car will be the software and features. Other than that it is what the tuner feels most comfortable with that can get the owner the results HE/SHE desired.
There will be no magical P&P unit that will solve the worlds woes.
For example, saying that one brand of screw driver is better than the other.
A tuning TOOL is a device used to make adjustments to the way a car runs.
No one should confuse the TOOL used to the changes made. I hope this very critical distinction is grasped by anyone reading this.
The first issue that anyone making an inteligent observation on any tuning device is to determine what kind of device you are dealing with.
Modern cars work with EFI units which work in compliance with OBDII and they suprizingly share a lot of common features due to the legislative resources of the CARB. An ecu is bascially a microprocessor which gathers input signals from various sources (e.g. crank position sensor, air flow meter, MAP - pressure - sensor, etc). The program in the ecu directs how the outputs (e.g. spark and injector on time etc) will function. Very basic system.
There are essentially 3 ways to "tune" or change the way a Evo X runs.
The first method is by INTERCEPTING or MANIPULATING the input signals to get the ecu unit to react in different ways. For example, generally lowering the MAP signal (boost or pressure) which is a 0 - 5 volt sensor will result in the ecu providing less injector on time and more ignition. Changing other signals going into the ecu such as crank position sensor can have an effect on timing. Generally an interceptor type device is easy to install and make adjustments but somewhat limited in what you can adjust and often involves having to make trade offs and compromises in order to achieve the desired result.
The Second Method is with a reflash device - there are serveal already available such as Ecutek or Cobb which make tuning changes by telling the ecu how to react to the inputs by changing the look up tables. For example you can change the a/f target at 4,500 rpms and a load of "X" by directly adding or subtracting to the fuel table. You can also rescale the injectors. There are lots of things you can do and most of the changes you make will not have unintended effects on other aspects of ecu operation.
The Third Method involves removing the stock ecu and installing a motorsports ecu such as an autronic or hydra ems. This type of soulution is generally more well suited to a track only race application.
My point is comparing these approaches to ecu adjustment is to say that each method of adjustment has its own advantages and disadvantages.
ALL of the methods can effect WHP and can be used to effect power delivery.
I would have thought that anyone with an understanding of how these tuning tools operate would agree that a reflash is the more effective method to adjust the stock ecu. However, it would be foolosh to assume that an interceptor device could not make the same power with the same boost, a.f and timing outputs.
To sumarize, it is important to distinquish between the TOOL used to tune a car and the TUNING style and approach used.
Al
stock X with ecuteck tune /bone stock/ runs 12.5 /4/ and 110 mph + .
So there is one number for you guys to chew it on.
There is no dyno calibration or type argument there.
cheers Rob
cheers Rob
What we are talking about is 2 stock EVO Xs doing the tests, or two Xs with the EXACT same mods. If they both baseline within a couple hp of each other, then there's no reason to say that the test isn't legitimate. Why are you so against this test? Does that strike anyone else as a little odd? If you are confident in your product, then measuring it against the competiton should be no problem.
i never heard such a thing as a stupid test. Every test is good for something
But in this case , the idea is very legit. Fact , it is interesting
if any one have a cat back and the drop in + zchip. /no boost controler/ in NJ.
i'm up for the comparision to help to the community.
I'm willing to drive 150 miles if it needs too.
Rob
its not enough to compare 2 evos with exact mods on same dyno, the best comaprison is the SAME car, same dyno, same day, ecutek v. zchip.
you can then compare peak numbers, graph curves and tan unbiased owner would have to take car for a drive and see how it feels smoothness, accelaration, etc.
this still would not be a perfect comparison but a relatively fair one,
it would be even better if that same driver say had a chance to take car to drag and do few pulls on car and see what #s are attained there.
but thats a lot to ask for
other than that, you started a thread that will end up in a ditch
All it would take is two customers with Xs, one with a custom ecutek tune and one with a custom Z chip tune (or one with a mail in flash and one with a base map from TTP (equivilant to a mail in flash in essence), to drive to an independant dyno tuning facility and have the cars run back to back. Easy as pie.
Exactly the purpose of this thread, my man. I've made the same point that you just made a million times, but people don't listen. Instead, they see a dyno graph from TTP and say, "100 whp gain, that's twice as much as any ecutek I've seen... it must be better."
What they don't realize is that like we've both said, assuming that each interface offers similar parameter control, it comes down to the fuel octane's limitations of how much boost and timing can be run, as well as the tuner's skill level. What this thread will do is show that when run on the same dyno, the peak numbers will be very similar and it will hopefully put to rest all of the confusion regarding the reality of tuning for the newbs out there.
It will also show that depending on how a dyno is calibrated, it will vary in not only baseline numbers but gains as well. Let the comparisons begin!
To those that want to participate: state the city that you live in and which EMS you have (z chip or ecutek) and once we find some people in the same area with both, a vendor/shop owner in that area can chime in and arrange a dyno day to do the test. Now, the tests will need to be monitored so that no funny business goes down, such as spraying one car's IC with NOS to bias the test, etc. So, people... step up to bat and let's get this done!
1 car, 2 tests is the only way to do a fair back to back comparison.
If your going to use 2 cars you adding in 1 more variable to the equation if you ask me.
I think it is a good idea to do a comparison, but not like this. Plus, trap speeds will always give you the real world results your looking for. If a zchip car traps 112 and a ectutek tuned car traps 112, what difference do you expect to see on the dyno?
I also think it is pretty lame to say TTP dyno reads high. That could be considered slanderish and pose negitive results on TTP's business. Unless you have first hand proof, your claim is pretty much hear say unfortunately.
i would like to see this test as well.
i was about to buy the z-chip when ttp told me that with the mods that i have on my car i would only gain about 30-40 AWHP so i would like to see the difference between the ecuflash and the z-chip
For months now, many people have been talking about the power gain differences between a reflash and the new Z chip. The problem is that the Z chip hasn't been dyno'd at anyone else's shop other than TTP's, and with their dyno reading much higher than most, it's hard to really compare it to the results from an EcuTek flash. Now, it has already been shown that stock X's with ecutek and the Z chip alike seem to both run about the same times down the strip, so that is something, I suppose.
you can then compare peak numbers, graph curves and then unbiased owner would have to take car for a drive and see how it feels smoothness, accelaration, etc.
Yep. Both the z-chip and Ecutek have yielded good/similar results. To perform such a "test", with all the hassle and complications that would be involved, it doesn't justify for it. People just need to research and pick what they want to go with.
Only thing I am confused with is how you say TTP's dyno gives inaccurate gains. You said high at first but then you said it show's higher gains as well. It's one thing for a dyno to read slightly higher than another, but they are advertising whp gain, which is going off of a baseline. So unless their dyno just doesn't work, the idea of providing a baseline is to prevent this sort of argument, that their dyno reads high, am I not correct?
