To all X owners using the Profec B
Old Dec 29, 2008 | 08:00 AM
2 Deep Motoring's Avatar
I am having trouble with controlling my boost wit the Greddy Profec B and i was wondering what the other evo x owners have their boost % , gain and set gain to and what psi they are running! please help!!
Old Dec 29, 2008 | 08:20 AM
BoricuaEVOX's Avatar
My car is modded and tuned, but later on i'll go outside to the car and write down the settings that i have for low boost. maybe that help out a little at least.
Old Dec 29, 2008 | 12:11 PM
thanks man!
Old Dec 29, 2008 | 01:31 PM
Sorry, left to get a haircut and forgot to get you the numbers. Here they are and I hope they work out for you. Let me know how it goes.
SET: 54%
GAIN: 10%
SET GAIN: 180
WARNING: 240
WARNING: L.20%
PEAK: 269
Old Dec 29, 2008 | 03:49 PM
i have my set at 80% and im still only boosting 18
Old Dec 29, 2008 | 08:23 PM
My "hi" setting will have you boosting between 25-26.5 psi. I don't know what you have done to your car, but if you need those let me know and i'll hook you up tomorrow
Old Dec 30, 2008 | 09:37 AM
Joe's Evo X's Avatar
Hey if you are untuned then it will never be perfect. I had it on untuned and had to take it off then got it tuned and it works good now.
Old Dec 30, 2008 | 02:21 PM
yea thats what i was thinkin also but did your car throw into limp mode and CEL ?
Old Dec 30, 2008 | 07:13 PM
Ivan@AMS's Avatar
The most common reason for seeing low boost on a Profec B is from not removing the factory cap in the 3rd unused port of the boost control solenoid.
Old Jan 3, 2009 | 02:20 AM
itznoraa's Avatar
interesting info, cause i overlooked that a few times when i first installed it.
to the op, my car throws a CEL light sometimes, i ran the code and it was "fuel pump out of range" . But it usually turns off.
Old Jan 8, 2009 | 07:51 PM
06 SLOW EVO's Avatar
im having this same problem now, i took my car to get a clutch installed and before it was running 20psi at around 55% i think but now i turned it up all the way to 80% after i got the car back and it wont go past 18.4????? does that sound like a leak that was caused when they did the clutch job?
Old Jan 13, 2009 | 01:23 PM
it could be you have a leak if they removed any IC piping... do a boost leak check and you'll find out
imma try that now and see how that goes... thanks for the advice
