MR with MBC
Old Feb 2, 2009 | 10:00 PM
Yousef's Avatar
MR with MBC
Hi,
hopefully I'll be getting my pkg from TTP bext week.
- Zchip
- Unos MBC
- Prosport premium boost gauge
- Eibach pro kit
i have zero experience with MBC, how do you set the boost with MBC and make sure it is correct on Evo X SST?
Old Feb 2, 2009 | 10:10 PM
Seb's Avatar
Seb
Originally Posted by Yousef
Hi,
- Zchip
- Unos MBC
- Eibach pro kit
You want to make sure you have a boost gauge to prevent running too much boost.
Old Feb 3, 2009 | 11:50 PM
Yousef's Avatar
^ of course...thanx
lets say i want 25 psi for example
how do i know if i set it correctly?
Old Feb 4, 2009 | 02:23 AM
SiC's Avatar
SiC
^ of course...thanx
Hook up the MBC between the pressure side vacuum line and the turbo actuator. Turn the MBC to the lowest boost setting (usually counter clockwise) and drive in 4th gear from 2500-4000 RPM (uphills is best) at WOT. Check your highest boost, should be around 12 psi. Gradually increase the boost (turn clockwise) and repeat until you hit your target boost (25psi).
