Cobb AP Tunes...
Old Feb 9, 2009 | 12:22 PM
tdubevox's Avatar
Cobb AP Tunes...
2 quick nube questions.....
1. If I have two cars with the same mods can I use the same Cobb AP or do I need to purchase two of them?
2. Do the tunes compensate for ambient temperature changes and the affect on boost or should you have a "summer" and "winter" tune?
Old Feb 9, 2009 | 12:42 PM
goofygrin's Avatar
not sure on 2, but the AP marries to the car, so you can't use one on multiple cars.
Old Feb 9, 2009 | 01:01 PM
cplise's Avatar
#1 is most Defiantly a no ( just thought you may need to hear it from 2 people )
you can uninstall it from one car and use it on the other ( not sure how that would be helpful ).
#2 ( i am not a guru ) BUT... the ECU can learn to adjust the timing and fuel if it needs to overtime ( learned Knock retard and LTFT )... There could be more LEARNED parameters but those are the 2 i know of.
Old Feb 9, 2009 | 02:13 PM
Rob@cobbtuning's Avatar
#1 looks covered.
#2. There is really no need for a seasonal tune, ECU will handle what is need. If a lower quality fuel is used in the winter time, we have a map to cover that scenario as well.
Thanks,
Old Feb 9, 2009 | 10:43 PM
lewvsal's Avatar
hey can someone with a ap throw out some gas mileage numbers they are getting with the econ map? gracias
Old Feb 10, 2009 | 08:37 AM
tdubevox's Avatar
Thanks for the replies! I will be purchasing one by the end of the month!!!
Old Feb 10, 2009 | 09:27 AM
goofygrin's Avatar
I'm not using the econ map, but with the custom tune I'm averaging just about what I was without the tune. *maybe* slightly higher around town but I think that is because I don't have to be on it so much because of more power down low.
Old Feb 10, 2009 | 11:48 AM
cplise's Avatar
my mpg read out has not worked since I flashed. So I really could not tell you. I hope Cobb fix's that soon.
Old Feb 10, 2009 | 03:50 PM
That would be interesting, our Evo's trip computer is working as expected. Can you described the behavior of your MPG readout?
Thanks,
Old Feb 10, 2009 | 03:58 PM
FknWitdee's Avatar
I am also interested in this info. Thanks
Old Feb 10, 2009 | 04:57 PM
sl0ev0's Avatar
i have my car flashed with the AP and i get my mpg readouts
Old Feb 10, 2009 | 06:58 PM
cplise's Avatar
Not sure why then, mine just reads 0/----- ? any advice... also i cant change maps?
Old Feb 10, 2009 | 08:26 PM
Jblade's Avatar
I get 26 mpg in mixed highway and local (daily commute) but only if I'm cruising in between 60-70 and no WOT runs at all. That first stab of the throttle ususally drops the gas meter and kisses good MPG goodbye.
I'm hard headed so I had to go in limp mode a couple times before realizing the economy map is not for me. If you get on it hard, it will overboost and or the throttle position will go "out of range". I l like having the choice to swap, but the economy map is literally a neutered Evo.
This in no way is a negative about the econ map or the AP, as it clearly states in the map notes that it is NOT for aggressive driving of any kind. Just an FYI.
As for city MPG, I get inbetween 18-20 (which is better than the 14MPG i would get on a good day with the stock tune)
Keep in mind this is me with the standard math "miles per a tank" method and not the AP or the Dash info screen
Hope that helps
Old Feb 10, 2009 | 10:15 PM
cplise's Avatar
Ok Rob@Cobb
I reset the meter and it appears to be tracking MPG? I guess just a reset is in order when you flash. i am gonna try changing maps... last time i tried it kept failing. ill let you know.
Old Feb 12, 2009 | 02:29 PM
dierr's Avatar
is it possible for some1 to sell the ap after they married it to their car? i'm curious because i just purchased one from a guy and don't want it to be still married to his car and wont work for mine...?
