ECUFLash speedcut on JDM
Old Jun 24, 2009 | 12:25 AM
ethanhunt's Avatar
Speed limit JDM GSR SST
I have a JDM GSR SST and i'm trying to remove the speed cut limit for my car. For some reason i don't see the speed limit settings and there's only a few settings i see. I can't even see my ECU ID. Anyone having this same issue? Any help on this would greatly be appreciated.
Old Jul 22, 2009 | 12:41 PM
voltexct9a's Avatar
Originally Posted by EvoHarumi
Perhaps, speed limit map is
53FC2
53062
533DA
This value is a guess from the magazine of Japan.
hey guys..
can u help me out? i'm trying to remove the speed cut on my jdm evo x..
where do i locate these cells and how do i edit them?
i tried to add new map in ECUflash but doesn't seem to be working..
thanks!
Old Oct 15, 2009 | 08:14 AM
EvoStormTrooper's Avatar
Originally Posted by burnings
Yes these works!
when u said these worked, u mean u got the speed limiter removed?
update 21/oct/09
those addresses works in ecuflash and got the speed limiter removed!
thanks yokohama_evox and EvoHarumi!!
arigato hontoni
Old Oct 21, 2009 | 06:09 AM
ethanhunt's Avatar
JDM Evo X SST Definition
Originally Posted by yokohama_evox
Please replace this line following with a description of speed limiter of contents of evo10base.xml.
<table name="Speed Limiter #1" category="Limits" type="2D" scaling="VehicleSpeed">
<table name="X" type="Static Y Axis" elements="2">
<data>Limiter ON</data>
<data>Limiter OFF</data>
</table>
</table>
<table name="Speed Limiter #2" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
<table name="Speed Limiter #3" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
and replace this line following with a description of speed limiter of contents of 52360016.xml.
<table name="Speed Limiter #1" address="53062">
</table>
<table name="Speed Limiter #2" address="53fb2">
</table>
<table name="Speed Limiter #3" address="533d2">
</table>
Yokohama_evox, Since you have a JDM SST could you probably help me figure out the definition for my JDM Evo X SST? I would greatly appreciate the help.
Old Oct 22, 2009 | 07:38 AM
yokohama_evox's Avatar
I'm sorry...
I'm sorry. I wrote in the address that I found on this bulletin board at a definition file this time. Therefore I cannot meet your expectation.
Old Oct 27, 2009 | 09:46 AM
Stradale's Avatar
Any solution to this problem? .. I am waiting for the answer too ... Evo X JDM manual trans .. thanks
Old Nov 30, 2009 | 06:22 AM
ethanhunt's Avatar
update 21/oct/09
arigato hontoni
How did you manage that? I tried those settings and i still have the speedcut at 190km/h. Btw do you see 3 speedcut limit option after edit the evo10base.xml and the other .xml ?
Old Apr 5, 2010 | 12:32 AM
yewkhip's Avatar
I've evox sst jdm with ecu id 52370023, i had change the value of 53062, 53fb2, 533d2 to 300 but still got speed cut at 185km/h, any idea? I'm using ecuflash 1.42
http://www.megaupload.com/?d=R6D5B0L1
Old Apr 8, 2010 | 06:58 AM
53FC2
53062
533DA
this one worked for me!
Old Apr 9, 2010 | 01:10 AM
yewkhip's Avatar
i had change these three table to 300, then try 510, still can't remove it, got any missing?
Old Apr 10, 2010 | 04:23 AM
not really sure bro, i changed those three and the speed limiter was gone,
i changed it all three to 300
Old Jun 6, 2010 | 05:40 PM
alto's Avatar
could someone tell me how to edit the speed limiter content of the evo x
Old Jun 6, 2010 | 08:50 PM
Golden's Avatar
You need to have the tables defined. (What ROM are you using?)
It should have an Limiter On speed and a Limiter Off speed. The on speed is how fast you have to go for before it kicks in. The Off speed is how fast you have to be going before it will let you control speed again (aka how much you have to slow down to).
Old Jun 10, 2010 | 10:33 AM
Stradale's Avatar
Any update for the EVO 10 JDM manual 5 speed speed limit removal?
If so please guide me how to do it? because even when speed limit number already change to 300 or max number, the speed limit still there.
Thanks
Old Jun 10, 2010 | 07:50 PM
Stradale's Avatar
Bump
