ECUFLash speedcut on JDM
Old Feb 14, 2009 | 02:24 PM
burnings's Avatar
Hi,
I am on EVO X GSR and the speed cut function on the ecuflash seems to have no effects at all.
The current setting is at 510 but speed cut still activated at 180km/h
Did anyone else have the same problem?
Old Feb 16, 2009 | 11:06 PM
AlGontsov's Avatar
This value is on the most if the Lancers, maybe it's require for some scaling?
Maybe x/2.83
Old Feb 17, 2009 | 02:40 AM
burnings's Avatar
Maybe x/2.83
510 is the max it can go
Old Feb 17, 2009 | 03:40 AM
kenx's Avatar
According to the magazine in Japan,speedcut has three maps.
You may examine the value of an address below.
But, I do not yet try it.
address="53062"
address="53fb2"
address="533d2"
good luck!
Old Feb 17, 2009 | 04:40 AM
burnings's Avatar
address="53062"
address="53fb2"
address="533d2"
good luck!
Hmmm... 533d2 has a stock value of 42 which 53fb2 consists of 3 digits which I cant see as it only shows 1..
Old Feb 17, 2009 | 07:10 AM
yokohama_evox's Avatar
Hi,
Perhaps three addresses are right. In ECU finished with tuning of the GSR SST of the model for my 2008 years in three addresses a constant value (Limiter on:380km, Limiter off:378km) is set.
Because I made a xml file for trial, please use it if good.
File Type: zip
Old Feb 17, 2009 | 01:39 PM
burnings's Avatar
Originally Posted by yokohama_evox
Hi,
Hi Yokohama, I cant seems to open your attachment.
Old Feb 18, 2009 | 08:50 AM
test
Old Feb 18, 2009 | 09:04 AM
Please replace this line following with a description of speed limiter of contents of evo10base.xml.
<table name="Speed Limiter #1" category="Limits" type="2D" scaling="VehicleSpeed">
<table name="X" type="Static Y Axis" elements="2">
<data>Limiter ON</data>
<data>Limiter OFF</data>
</table>
</table>
<table name="Speed Limiter #2" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
<table name="Speed Limiter #3" category="Limits" type="2D" scaling="VehicleSpeed">
</table>
</table>
and replace this line following with a description of speed limiter of contents of 52360016.xml.
<table name="Speed Limiter #1" address="53062">
</table>
<table name="Speed Limiter #2" address="53fb2">
</table>
<table name="Speed Limiter #3" address="533d2">
</table>
Old Feb 18, 2009 | 02:42 PM
burnings's Avatar
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
kekeke I already did that and I have some interesting find. 53fb2 have a default value of 1392 and 533d2 has 46.
Anyone already tried these settings?
Old Feb 19, 2009 | 02:27 PM
Deepseadiver's Avatar
any results?
Old Feb 21, 2009 | 05:44 PM
EvoHarumi's Avatar
Perhaps, speed limit map is
53FC2
53062
533DA
This value is a guess from the magazine of Japan.
Old Feb 25, 2009 | 12:54 AM
EvoHarumi's Avatar
It will test in this Address next week.
Old Mar 1, 2009 | 08:30 PM
EvoHarumi's Avatar
There was no trouble though the test run was done.
However, truth is not understood.
Because it did't verify the address that other people showed.
Old Mar 2, 2009 | 01:50 PM
burnings's Avatar
53FC2
53062
533DA
Yes these works!
