Limp mode [merge]
Old Mar 19, 2009 | 01:04 AM
  #46
ksig419's Avatar
does anyone know if the stock 9 BOVS are the same as the 10. I would like to trade someone for a stock BOV for an HKS
Old Apr 11, 2009 | 02:58 PM
  #47
simons's Avatar
Limp mode?
When exactly does the ECU go into limp mode? I know you can sometimes hit fuel cut with a test pipe on certain cars but I don't know if that's the same thing as limp mode. I read on a forum somewhere that you can get one or the other if you have sustained boost of >25 psi for 3 seconds or more. Is this true?
I would assume you can reset it if you disconnect the negative battery terminal for about 5 minutes.
Old Apr 12, 2009 | 07:54 PM
  #48
bigmiketino's Avatar
I can tell u if u vta and raise the boost it will throw u into limp mode.In 5th gear going 80mph sucks real bad.
Old Apr 13, 2009 | 03:29 PM
  #49
simons's Avatar
My stock BOV is still full recirc. I know VTA makes you temporarily run rich in between shifts and can mess things up. I've haven't experienced fuel cut or limp mode yet, let's hope it stays that way. Hopefully I will be getting a tune before too long.
Old Apr 20, 2009 | 09:43 PM
  #50
Spool's Avatar
New wheels, TPMS question
I just put on my new wheels today and I am not running the TPMS sensors. Ive put about 30 miles on the car and I still havent had the TPMS sensor light come on the dash or anything. Its just like I still have my factory wheels on. I figured the light would have come on as soon as I got out of range of my factory wheels in the garage. Is this normal?
Old Apr 20, 2009 | 09:47 PM
  #51
JoeyM3's Avatar
it takes about 100 miles for the car to recognize that the tpms are not on the wheels
Old Apr 20, 2009 | 09:59 PM
  #52
Spool's Avatar
Really? Thats odd.
With factory wheels. If my tire pressure gets too low, does it take 100 miles before it tells me to add some air?
Old Apr 21, 2009 | 12:01 AM
  #53
supergengo's Avatar
I would guess they programmed it that way so that if you get a flat and have to put on the wiener spare (which does not have TPMS), you can limp 100 miles without falsely thinking you are losing air in one of the other tires.
Old Apr 21, 2009 | 09:38 AM
  #54
Xtremist's Avatar
You should recognize it instantly.
Old Apr 21, 2009 | 09:57 AM
  #55
jimm's Avatar
Mine also did not show up until later.
I think the sensors must have two signals. 1 is "I have low pressure" and the other is a periodic pulse to tell the car it is there and working properly...after all, if it breaks, how would you know?
In the absence of the periodic signal, it throws a warning that something is broken, go to the dealer.
Must be on a timer because mine went off after about an hour but less miles.
Old Apr 21, 2009 | 10:11 AM
  #56
EVO-IX-MR's Avatar
Just hold down the SET and NAVI buttons to go into the service menu and turn the TPMS off if you don't want the warnings (when/if you get them that is).
Old Apr 21, 2009 | 09:04 PM
  #57
Aseller's Avatar
When I didn't have the TPMS in my tires it took awhile for me as well.
Old Apr 21, 2009 | 09:51 PM
  #58
MR Dan's Avatar
you got to do this everytime the warning light comes on
Old Apr 21, 2009 | 10:27 PM
  #59
Spool's Avatar
I cant do that because I dont have navigation
The light came on tonight on my way home from work.
Old Apr 23, 2009 | 07:10 AM
  #60
Noize's Avatar
EvoM Administrator
TTT for merge purposes
