EvoScan for Evo X Beta Parameter CAN-ID's? Log attached
Old Apr 27, 2009 | 04:52 PM
NMX's Avatar
NMX
Does anyone have a log of a completely stock GSR they'd like to share? That would really help give a better idea of whether we are logging the right values.....
Old Apr 27, 2009 | 04:53 PM
GST Motorsports's Avatar
Originally Posted by NMX
Thanks, that's what I've been told - the timing I'm logging is too high for a stock car with factory map. Does anyone have a log of a completely stock GSR they'd like to share? That would really help us have a better idea of whether we are logging the right values
I have a bunch. I will try to post them up later tonight.
Old Apr 27, 2009 | 06:13 PM
Guru's Avatar
Originally Posted by GST Motorsports
If it is stock, that timing at peak load is incorrect given a normal 2500 to 7500 rpm sweep
Definately not stock. FP Red and I beefed up the timing quite a bit from stock as am hitting different load sites. ECU never pulls timing but then again I am being cautious at only 22 PSI for now. Will be turning boost up another lb or two soon. Just have to do many logs to make sure it is safe and haven't had time to do that.
Old Apr 27, 2009 | 08:02 PM
WarmAndSCSI's Avatar
I see a low of 10 degrees with no apparent knock retard on my practically stock map. Also, a high of about 23 degrees BTDC at redline. It may be accurate.
Old Apr 27, 2009 | 08:29 PM
OK so I'm going to go and try to get boost and load logging working. Or at least get some time in on figuring them out. I wish I did this for a living or could take vacation right now to figure it out...
Old Apr 27, 2009 | 11:50 PM
Well I figured out another value instead. Knock count
I have my "Knock Retard" value set to CAN11-1 and it is definitely what I am used to seeing for "Knock Sum/Count." It's definitely not degrees of timing, seems like 1 degree timing per 3 "degrees" of this value.
Anyway, I also found that CAN7-0 is indeed accurate for Timing Advance.
Timing Advance: CAN7-0
Knock Sum/Retard: CAN11-1
I'll be working on MAP now cause I didn't even bother.
Old Apr 28, 2009 | 12:04 AM
One additional bit of info. I don't see how we can be logging actual load without combining two CAN return values. Since they are bytes, they have a range of 0-255 for integer values. Hence why we are seeing a maximum reported load of 255. There must be a 2nd value for load that can be added to the first to get "actual" load. Maybe it is CAN20-1 + CAN20-2. I'll try it later.
Old Apr 28, 2009 | 06:16 AM
loevo's Avatar
Thumbs up What can-settings so far?
Nice going gurus!
Would it be a good idea to summarize the discovered can-settings so far so that
mortals like me can try logging as well since I have the Evoscan SW and
an openport 2.0 cable.
I do not know if my logging would help but it would be interesting anyway...
I am reading up on tuning so I hope to be able to help eventually...
/L-O
Old Apr 28, 2009 | 03:28 PM
no
Old Apr 28, 2009 | 08:23 PM
LaXGSR's Avatar
WarmAndSCSI - Thanks for sharing! I will try these out as soon as I get a chance (crazy week here). Anyone else have feedback on the latest CAN ID's for logging?
Old Apr 28, 2009 | 08:34 PM
yw.
The knock count/retard one I posted is definitely spot on. I tested it on another X today and I was able to identify the dealer filled the poor car with 85 or 87 before it left the lot... 13 counts stock! Pretty ridiculous. Even after reflashing the car was still dumping fuel and pulling timing due to the detected knock.
Old Apr 28, 2009 | 08:54 PM
SiC's Avatar
SiC
Originally Posted by WarmAndSCSI
yw.
I was using 11-3 for knock retard but I'll try yours. It's hard to test knock if you don't have any
Old Apr 28, 2009 | 08:57 PM
SiC's Avatar
SiC
Here's another one, Octane 12-2, thanx to gunzo
Old Apr 28, 2009 | 09:41 PM
What kind of logging sample speed are you getting SCSI?
- Bryan
Old Apr 28, 2009 | 10:22 PM
I dunno about no knock, at least not according to what I'm logging. No matter how rich and how much timing I pull, I still see it hover around 1-2 "degrees."
- Bryan
EvoScan is telling me 64/sec so I guess 8/sec if I'm logging 8 items? That's about what I see in my logs. 6-8 per second. Not great, but it works I guess.
