turbo and torque
Old Jun 8, 2009 | 02:48 PM
malymabl97's Avatar
turbo and torque
Would it be possible to upgrade the turbo and tune it so that it does not produce a lot of torque at the low end but have a lot of HP at the high end?
Reason for the question is because I have a MR.
Old Jun 8, 2009 | 04:27 PM
SiC's Avatar
SiC
Upgraded turbos will generally give you more high end HP & torque. If you want to lower your torque in the low-mid range, you'll need to lower the boost in that range. Your tuner should be able to do that for you thru the stock boost control solenoids.
Old Jun 8, 2009 | 06:24 PM
jmorris1027's Avatar
http://www.max-boost.co.uk/max-boost.../big_turbo.jpg
/thread
Old Jun 8, 2009 | 08:20 PM
malymabl97's Avatar
That turbo is a little bigger than what I was thinking.
Old Jun 9, 2009 | 12:56 AM
tephra's Avatar
yes to your OP
