O2 location for logging
If you pull the primary o2 sensor your car won't run for ****.
You can use the secondary o2 sensor bung, but your car will throw a code (likely P0420) -- although it won't hurt the car or cause it to run funny.
I recommend welding a new bung on the car and using that. It needs to be in the 9oclock to 3oclock position (not hanging down).
Most widebands suggest a location at least a couple feet from the exhaust port outlet. Read the instructions that came with your wideband. I highly recommend choosing the location carefully and make sure you weld the bung in a place that is as easily as possible to get at. Mine is about in the middle of my downpipe.
Mine is on the test pipe since it's easier to get in and out that the o2 housing/downpipe.
Right now, you can't disable the rear o2 sensor on the x's, otherwise you could do just as on the scoobies.
I made the mistake in saying where I put my sensor for my VI. So for a X use your best judgement and find out the easiest place... downpipe, test pipe, etc.
haxr303
Jul 3, 2016 07:50 PM
