Why to log the Battery Voltage on EvoScan?
Old Jul 17, 2008 | 08:16 PM
racer135's Avatar
Why to log the Battery Voltage on EvoScan? I guess it has to be something related to the injectors or fuel pump? Anyone know? What about the O2 sensor? Whats the use of logging O2 if you have a wideband.
Old Jul 17, 2008 | 08:28 PM
fryedchikin's Avatar
Battery Voltage is used for Calculated Load if you aren't using the 2 Byte Mod.
Old Jul 17, 2008 | 09:02 PM
racer135's Avatar
I log both LoadCalc and 2 Byte Load without logging battery voltage.
Old Jul 17, 2008 | 11:10 PM
nj1266's Avatar
I only log the battery when I am doing injector scaling/latency. I log 2byte load so I do not need to log battery for loadcalc
Old Jul 17, 2008 | 11:56 PM
RazorLab's Avatar
FYI the "battery" voltage decreases at WOT.
Old Jul 18, 2008 | 12:29 AM
tephra's Avatar
probably coz the alternator turns off...
Old Jul 18, 2008 | 04:58 AM
Maybe you are using a different function for LoadCalc. This is what I am using....
5*[InjectorScaling]*((0.256*x)-(-0.1026*[Battery]+1.8741))/(14.7*128/[AFRMAP])
Old Jul 18, 2008 | 05:40 AM
racer135's Avatar
Opps. You are right. I do log Battery Level for the LoadCalc. I did not realized it because I never look at it. Anyway I was just curious why Mellon ask lo log Battery Level. It has to be because of the Load Calc.
Thanks!!
Old Jul 18, 2008 | 06:42 AM
Mellon Racing's Avatar
correct If you only check loadcalc and try to start logging it'll tell you to check a few other things so the formula will work. If you've done the 2byteload mod then you can just log that. It's a little more accurate anyway.
Mad_SB
14
Oct 4, 2017 04:08 AM
zack meg
Jun 18, 2017 05:17 PM
black_beauty
Aug 20, 2012 10:11 AM
my04s2k
Jul 7, 2010 07:03 AM
antzlim
Apr 18, 2004 01:03 AM
