electronic throttle
Old Jun 19, 2009 | 07:55 PM
  #31
tephra's Avatar
ok - here are some more tables which are in usual driving conditions make up the X-axis for the Throttle Map tables:
Code:
    <scaling name="ThrottleInput1" units="units" toexpr="x*3" frexpr="x/3" format="%.0f" min="0" max="510" inc="1" storagetype="uint8" endian="big"/>
    <table name="2) Potential X-Axis Throttle Table 0x5936e (interpolated/cold)" category="Misc" type="3D" swapxy="true" scaling="ThrottleInput1" address="0x59375">
        <table name="Unknown" type="X Axis" elements="17" scaling="Hex16" address="0x613e4"/>
        <table name="RPM" type="Y Axis" elements="16" scaling="RPM" address="0x6135e"/>
    </table>
    <table name="2) Potential X-Axis Throttle Table 0x59486 (interpolated/hot)" category="Misc" type="3D" swapxy="true" scaling="ThrottleInput1" address="0x5948d">
    </table>
As you can see the max in the table is 429, so under normal driving conditions the X-Axis of the Throttle Maps wont go above 429 - hence I *think* if you smooth the throttle maps across you are limitting your max-throttle.
I am working out the X-Axis for these new tables as we speak.
Old Jun 19, 2009 | 08:15 PM
  #32
tephra's Avatar
^ thats for 53040010 here is a pic of the table:
so to be verbose - the output of THIS table is used as the X-Axis for the Throttle Maps table
Old Jun 19, 2009 | 08:25 PM
  #33
Hiboost's Avatar
apparently there is a blitz throttle controller for the X and it adjusts the speed at which the throttle valve opens. Is that what the other map could be for? Extreme mode on the blitz opens the valve 4x faster than economy mode.
http://www.nengun.com/blitz/throttle-controller
Yeah i saw that where they were basically amping up the throttle sensitivity where as we are actually trying to make it more even.
I noticed this the other day when I specifically tested acceleration with the throttle pushed down at 30% and watched as boost fell off and throttle decreased as RPM's rose even though I didn't change the position of my foot. I'm not sure I'll extend the max values as high as you guys did but evening out the cruising range and widening the low RPM range somewhere between where it is and what cruising RPM's ends up being.
Old Jun 19, 2009 | 08:31 PM
  #34
tephra's Avatar
yeah its because at higher RPM's the X-Axis to the throttle maps actually drops (as you can see by my table I posted above, look at the 333 column, 429 -> 336)
I am not sure why Mitsu have done this...
Old Jun 19, 2009 | 09:43 PM
  #35
HB Speed's Avatar
I was right!! there is another table !!!
Old Jun 19, 2009 | 09:46 PM
  #36
tephra's Avatar
hehe
there's _always_ another table...
this ROM has got more tables, than US-Government has bailout dollars ok well maybe not :P
Old Jun 19, 2009 | 11:42 PM
  #37
BigT's Avatar
And, I JUST got into using ECUflash. I have so much to learn!
Old Jun 20, 2009 | 03:48 PM
  #38
HB Speed's Avatar
I had to shift the tables a bit
but the rpm is meh
Old Jun 22, 2009 | 01:34 AM
  #39
gunzo's Avatar
You have a msg .. actually you have a reply
Old Jun 22, 2009 | 06:45 AM
  #40
tephra's Avatar
email me if you want private
myforumname @ gmail.com
Old Jun 23, 2009 | 10:48 PM
  #41
HB Speed's Avatar
HMMMM
Old Jun 24, 2009 | 12:10 AM
  #42
tephra's Avatar
52680015 -> 20:
Code:
    <table name="2) Potential X-Axis Throttle Table 0x5936a (interpolated/cold)" category="Misc" type="3D" swapxy="true" scaling="ThrottleInput1" address="0x59371">
        <table name="Unknown" type="X Axis" elements="17" scaling="Hex16" address="0x613a8"/>
        <table name="RPM" type="Y Axis" elements="16" scaling="RPM" address="0x61322"/>
    </table>
    <table name="2) Potential X-Axis Throttle Table 0x59482 (interpolated/hot)" category="Misc" type="3D" swapxy="true" scaling="ThrottleInput1" address="0x59489">
    </table>
The OUTPUT of these tables are used as the INPUT to the TPS3/4/5 tables...
Old Jun 24, 2009 | 09:37 AM
  #43
MR. Tim's Avatar
In for updates and later reading
Old Jul 1, 2009 | 02:44 PM
  #44
Bob_tm's Avatar
Any news?
I make small log. Delay between APP and TPS is around 0.8 second when i press the pedal and 0.4 second when I release the pedal.
Old Jul 2, 2009 | 12:05 AM
  #45
Bob_tm's Avatar
This was for EDM evo. Could someone log APP and TPS delay on USDM or JDM evo? This will help to reduce this stupid delay.
