electronic throttle
Old Jul 6, 2009 | 05:53 AM
  #61
Bob_tm's Avatar
What about rev hang and APP response delay ? We are waiting for Tephra X-mods ;-)
I dont think I need todo any more disasm in the throttle maps area, I wanted to understand how they worked and I think I understand enough now, I particularly wanted to find out if smoothing the maps across to 100% of the X-Axis was a good idea - its not...
Old Jul 6, 2009 | 06:20 AM
  #62
tephra's Avatar
Got a log of the APP delay? I don't experience this...
Old Jul 6, 2009 | 11:53 AM
  #63
Bob_tm's Avatar
Yes! This is edm evo.
http://babenko.info/cars/evo/throttle.csv
Some can be fixed using maps, but not all
Old Jan 5, 2010 | 08:28 AM
  #64
Clipse3GT's Avatar
BUMP
Is there any more info on adjusting these tables and how they exactly work?
Old Jan 5, 2010 | 09:13 AM
  #65
xPRimNT's Avatar
Awesome information everyone.
I have a question in regards to this though! I had a question recently from someone wishing to have the throttle mapping of "Sport" mode of the SST copied to "Normal" mode.
Has there been any development in differential maps linked to specific modes for the SST versions?
Old Jun 28, 2010 | 12:41 AM
  #66
Bob_tm's Avatar
Some new information?
Old Jun 28, 2010 | 12:44 AM
  #67
tephra's Avatar
yes a lot has been found out.
but nothing that I want to post about yet...
I have spent about 80 hours look at this code the last couple of weeks, its very complex (overly so)
Hopefully I am nearing the end and will be able to announce something soon.
Old Jun 28, 2010 | 12:20 PM
  #68
fostytou's Avatar
EvoM Community Team
Very interesting, thanks for the insight!
Old Jul 4, 2010 | 02:00 PM
  #69
EvoXCR's Avatar
Suscribed...
Old Jul 5, 2010 | 07:01 AM
  #70
Mitsiman's Avatar
subscribed also interested to see the final results and guide to the DBW maps
Old Jul 9, 2010 | 03:25 PM
  #71
rocksparow's Avatar
Agree with Ken Barr. cables work great and the cost of replacing a cable is not that much if they do need to be replaced...some of the costs I've seen for FBW problems exceed a thousand dollars in some cases..I don't get it...
Old Jul 21, 2010 | 06:25 AM
  #72
therocket's Avatar
Just to be sure I understand correctly, at the end the X axis of the throttle maps is not directly APP but it is related to it, or in general it can be considered as the request coming from a "torque based" model, so we can say a "target torque".
From this (and from rpm) the throttle map gives you the TP you need to obtain that target torque; then, basing on this TP, the BTEL gives you the engine load (=airflow) you need to obtain that target torque and so the boost pressure is adjusted to obtain that load and, at the end, that target torque.
Is this calculation chain correct?
So, this pic (coming from this topic: https://www.evolutionm.net/forums/ev...10-thread.html) where on the X asis of the throttle map there's the LOAD is not correct: click here for full size pic.
Just one more question: in the throttle maps and also in the "reactive solenoid max total upward WGDC correction" table, the TPS goes from 0 to 100%; instead in all the other tables (BTEL, reactive solenoid base WGDC, etc) it goes only up to 80.4%: why? Is it the same? I mean, 100% in some tables is the same of 80.4% in others?
Thanks very much for your answers...
Old Jul 21, 2010 | 07:03 AM
  #73
tephra's Avatar
not really, its ultra complicated
i posted up a thread on the correct axis for boost maps - its in this forum pretty recently
Old Jul 21, 2010 | 07:09 AM
  #74
therocket's Avatar
Yes, I've read it but at the end a difference between some tables (TPS 100%) and some other (TPS 80 or 90%) is still there, so I don't uderstand this completely...
Instead, about the "calculation chain" from APP (or requested torque, let's say) to throttle position and engine load, what I've written is quite correct...?
Thanks
Old Sep 23, 2010 | 11:01 AM
  #75
EvoXCR's Avatar
Don´t mean to be a PITA but has somebody found anything about how DBW works on the X. I´m interested in tuning it, if it is possible, but have no info on how it works to begin with...
Thanks!
