P1241 CODE questions
Old Jun 27, 2009 | 11:33 AM
AIK's Avatar
AIK
We have flashed EvoX with INJEN intake, UR exhaust, EBC Blitz I-color.
We periodically have the 1241 and limp mode only when air conditioner "ON", when this one "OFF" - the car always works correctly.
And yet, this car is USDM 52680015. We are using similar tuning tables on EDM 54030007 (with the same kit of tuning components) and have not any problems with 1241 there. But i need say that i feel that this car (USDM) is the faster...
Any ideas?
Thanks.
Old Jun 27, 2009 | 06:42 PM
boostsaves's Avatar
Is there a heat shield on the intake? Cause i know when you have the ac on the hot air comes right into the intake path, and the maf freakes out since it has a rush of hot air.
Old Jun 27, 2009 | 07:37 PM
tephra's Avatar
whats 1241?
Old Jun 27, 2009 | 07:38 PM
tephra's Avatar
oh - torque monitor..
why dont you just increase the torque limit tables then?
Old Jun 27, 2009 | 07:44 PM
boostsaves's Avatar
oh ok didin't know offhand what the code was. That is your problem then.
Old Jun 28, 2009 | 12:46 AM
AIK's Avatar
AIK
I did it, but don't help. Probably in initial tables there is any logic which gets off at modification by hands. Initially we use airflow check and torque limiter cards from the tuning car which here cannot be mentioned .
Old Jun 28, 2009 | 12:57 AM
AIK's Avatar
AIK
I will try to make supply of cold air, in any case it will not prevent. Thanks.
cihat
Jan 21, 2015 01:25 PM
DSG Performance
EvoX 'For Sale' Suspension / Brakes / Handling
Sep 12, 2014 01:08 PM
JonGonzo
Jan 15, 2014 01:58 PM
JEDMESTON
Feb 17, 2013 05:40 PM
Force-Fed Performance
51
Jan 17, 2010 05:07 PM
