Warmup and Aggressive MIVEC Maps
That is what I do. There is no point in setting them different when warm-up is such a small part of driving and should be done conservatively anyway.
Just set them both the same. You shouldn't be driving your car agressive anyway until it reaches proper operating temperature.
So you can leave the warmup maps stock (ultra conservative), use my warmup maps (Moderate), or copy in the full temp maps (Aggressive-just control your right foot until you are warmed up!).
I will be taking my car to the dyno tomorrow, will do some testing on these MIVEC maps compared to the ones that came with the Cobb Stage 2.
Thanks for the clarification!
Right now I`m using your warmup and aggressive MIVEC map on my Cobb Stage 2 tuned map. From what I can see, the Cobb MIVEC is based on the USDM version with adjustments in only certain areas. Hiboost MIVEC maps are definitely more aggressive.
Will be doing a back to back run between the 2 MIVEC maps to see what the difference is at WOT.
I absolutely agree that you can set them the same as long as you (the driver) is responsible for proper warmup driving, especially when it's really cold out in the winter. That said, having them slightly more moderate is good for when you pull into traffic during a cold start and miscalculate how much throttle you are going to need. The less aggressive maps are more dummy proof for people like me.
I would love to see a back to back test of the Cobb Mivec maps versus the "Hiboost" mivec maps, something I forgot to compare on my last trip to the dyno. Likely 4th gear pulls will show the most difference and give best case scenario spoolup compared to 3rd gear pulls. While 5th gear would build boost earlier, it's also an overdriven gear and usually not used on the dyno.
Setting both maps the same just means who ever does it has no idea what they are doing ..
There is a reason why there's a temperature X-over ..don't ask me I don't know anything
Don't bother checking the Mivecs on the Cobb .. practical waste of time .. probably comes from not knowing how to do twin mivecs .. as were alot of us when we started ...
Lastly .. What is on the dyno is not indicative of what is on the road ... simple due to the way the ECU calculates the environmental loads .. What you see as gains at higher rpms on dyno with the exhaust mivecs will translate to a slightly slower car compared to the USDM settings.. the difference is quite glaring and can be felt when you change on the fly ..
Yeah I favor using a warmup map for safety's sake.
I plan on doing some thorough testing with VDR spreadsheets and doing 3 runs in the same spots and then compare the averages to 3 runs with the different MIVEC maps. Hopefully I can at least see a trend of where the car is accelerating faster through the RPM ranges. I agree that the Dynos don't always pick up the differences 100% accurately but a good load bearing Mustang Dyno is safer than street tuning and is better than nothing.
Thanks for the post. But, I have a question. Why do your generic maps share the same mivec settings on both of the maps? Are we worse off with more aggressive settings?
So I guess he does not know what he is doing as well
There are a lot of knocks (10-15 knockcount) for 100-160 load, 5000+rpm and bad 91 octane fuel. But it's works on 93 without problems. I simply retard some intake in this cells and it works even for 91. Timing was not changed!
You just got caught with your pants down. Your own maps have mivec 1 and 2 set up the same and you were telling us not to do it and that we do not know what we are doing.
You have no credibility on this issue.
Dude, you cannot run around telling people not to do something and then do it yourself. It is called credibility and you just lost it.
what Gunzo is saying is that his maps ARE NOT AGGRESSIVE so who cares if they are 1 and 2.
Gunzo knows FAR more about these cars and roms than you do and trying to discredit him (which you seem ti like to do to everyone ) is a slap in the face to the community and people YOU ask for help when YOU cannot figure out something....
Gunzo is one of the MAIN contributors to the ECU DEF XML's and Logging defs that YOU use to toon cars dude, good job burning a bridge.
i usually dont say anything about you and your ways but this is bullpuckey
