Stock log
Old Jul 16, 2009 | 01:17 AM
tephra's Avatar
Stock log
Hi Guys,
Anyone have a log (including AFR) of a totally stock car? (most recent ROMID if possible, I *think* Mistu leaned out the map didn't they?)
I want to compare it to mine to see how my LC1 is doing..
Cheers
D.
Old Jul 16, 2009 | 05:19 PM
LaXGSR's Avatar
Here's a stock log from 52680018 at high altitude, so the load is much lower than sea level logs. Would be nice to compare to other logs at sea level!
EDIT: Replaced with image to make it easier to read.
Old Jul 16, 2009 | 06:23 PM
tephra's Avatar
cool thanks.
ill post up my stock log (for roughly sealevel) in a second...
Old Jul 16, 2009 | 10:22 PM
tephra's Avatar
as promised:
Old Jul 17, 2009 | 07:37 AM
LaXGSR's Avatar
Thanks Tephra, I replaced my log with a chart also to make it easier to read. Looks like you're running quite a bit less boost than I am, but higher load. My load numbers were divided by 10 to make it easier to read on the same scale. I would guess that your LC-1 seems to be working correctly since I'm also seeing AFR's between 10.2-10.7ish.
Old Jul 17, 2009 | 07:45 AM
tephra's Avatar
yeh you need more boost to hit the same load... i am guessing.
ps if you rightclick on one of the lines - you can say "Format Data Series" then click "Secondary Axis"
then you can get some decent resolution (on say the AFR graph)
Old Jul 18, 2009 | 06:06 AM
LaXGSR's Avatar
Yup, my absolute pressures will be lower even with more boost Thanks for the Excel tip! I just did updated my log image above with finer AFR readings...now is there an easier way of saving the chart as a jpg as opposed to copy and pasting it into Microsoft Paint? Our AFR curves look pretty similar...
Old Jul 18, 2009 | 07:23 AM
tephra's Avatar
i just copy/paste -> paint
yeh pretty similar... i am going to re-wire the LC1 tommorow - its keeps reset its setting due to cranking... ACC is an unstable power supply - so I am going straight to the MFI relay hehe
Old Jul 21, 2009 | 07:48 AM
LaXGSR's Avatar
Hmm I haven't had any issues with my LC1 resetting using ACC power, but I have heard of others with this issue.
Anyone else have a stock log to share?
Old Jul 21, 2009 | 04:27 PM
tephra's Avatar
symptoms are LC1 will forget its analogue settings...
Old Jul 21, 2009 | 05:02 PM
nj1266's Avatar
Here is a stock log running the 015 rom id, the richest one. The ZT2 does not go lower than 9.6:1. The LM-1 does not work with Evoscan 2.4+ and Hamish does not want to fix it.
Old Jul 23, 2009 | 02:22 AM
HB Speed's Avatar
my LC-1 works fine.....
Old Jul 23, 2009 | 08:06 AM
nj1266's Avatar
LM-1 and LC-1 are different even though they are made by the same company.
