O2 Sensor Disable
Old Jul 23, 2009 | 11:13 PM
SiC's Avatar
SiC
Originally Posted by tephra
your looking at the wrong bit...
my AUDM roms have the bit enabled...
Hmm, I thought it was ECU Option Set #4 bit 13. The address I posted above changes this bit.
Old Jul 23, 2009 | 11:40 PM
tephra's Avatar
no ECU Options #2, bit 1 (as in second last bit)
Old Jul 23, 2009 | 11:54 PM
SiC's Avatar
SiC
Okay thanks, I wonder what the other one I posted was..... It's only enabled on the USDM.
Old Jul 24, 2009 | 12:55 AM
e_leo's Avatar
to those ppl that it works for - post up your romid AND whether you left the sensor IN or OUT
ROMID:52680015.
Removed from exh-4pin plug disconnected
Old Aug 1, 2009 | 05:41 PM
xbox4414's Avatar
Okay so in cell I do "= 0" and it doesn't change. If I use "[" to decrease the bit to 0 it changes cells above and below it... The displayed values of those cells are the same but it's show up in ECUFlash as a changed value... Any ideas?
Old Aug 21, 2009 | 02:18 AM
stokEd's Avatar
Originally Posted by e_leo
ROMID:52680015.
Anyone else tried this and have anything to report?
@tephra - If P-bit disable works for the 52680015 ROM (which is the ROM from the first USDM X's correct?) what would keep it from working for the subsequent ROMs that inherit from it, e.g. 52680020?
Old Aug 21, 2009 | 06:39 AM
drewgray's Avatar
ROMID: 52680018
Sensor is removed, and I keep getting an SES light, FYI.
Old Aug 21, 2009 | 06:20 PM
GTR2009's Avatar
and what error do you get?
Old Mar 16, 2010 | 07:41 PM
Piper747's Avatar
I also changed Option 2 bit.1 ->"0" and now have the p0140 code. I have the sensor removed and have my WBO2 feed to the sensor input.
ROM 53600010
Old Mar 16, 2010 | 08:25 PM
stokEd's Avatar
ROM 53600010
Go here for the P0139/0140 disable code: https://www.evolutionm.net/forums/ev...p1238-etc.html
Old Mar 16, 2010 | 08:28 PM
stokEd's Avatar
Hmmm, just realized you have a Ralliart... 53600010 isn't on the list.
Regardless, post your request in that thread.
Old Mar 17, 2010 | 11:55 AM
derekste's Avatar
52680020, Option 2 bit.1 works as expected with sensor connected (12k miles). Sensor has been disconnected for about 1k miles with no issues, either.
Old Mar 18, 2010 | 04:37 AM
BigT's Avatar
sensor connected and removed or still plugged into the exhaust?
Old Mar 18, 2010 | 07:33 AM
derekste's Avatar
connected and tucked in that little pocket under the car where the wires leave the cabin. I am now completely sensor-less (disconnected at the pigtail in cabin)
Old Mar 18, 2010 | 07:57 AM
goofygrin's Avatar
My ECU reports "NOT READY" so this fix won't pass inspection
