Service Engine Soon Light
Old Aug 7, 2009 | 04:17 PM
tim788's Avatar
ok so i went to advance auto and pulled the code...ended up being an ignition misfire. can anybody forsee this happening because of the richness of the car? like i said last night it was not on but this morning right when i started the car, the light came on and stayed on. takin it in to the dealer for further analysis but figured id share in case anyone had this same issue or if anyone could shed a little knowledge on this subject.......
Old Aug 7, 2009 | 05:30 PM
tim788's Avatar
well i did a little searchin and come to find out it seems to be an issue with earlier released cars, but there is a TSB to fix it. its not gonna hurt anything but might as well get the fix for free. suppose to run a little better after also, we'll see......
Old Aug 7, 2009 | 07:58 PM
sQuid^'s Avatar
I have had the K&N in for at least 8 months.
Old Aug 7, 2009 | 11:25 PM
hyprlan's Avatar
Originally Posted by JAMiEvoX
Happened to me also around same milleage. Check engine light came on and idle stood at 2500rpms. Went to the dealership and they replaced the MAF. No mods when problem occured.
Anyone else had this happen to them because it's happened to me about 3 different times already, is it the MAF sensor that need to be replaced???
Old Aug 31, 2009 | 07:10 PM
7warrior's Avatar
Service Engine Soon Light- error Code P1320
Hey, My Evo X Has only 6000 miles.... today around 5 am. When i turned My Evo on. My " service engine soon" light came on.... and Stayed on! I was soo freaking worried! So, i brought it to pep Boys... They were nice enough to give me a Free Computer Dianostics Reading. "awesome"
Anyways, the error code is P1320 " Ignition Timing Retard Insufficient" After searching online, ive notice that many other Evo X's are having the same problem! It sounds like a Manufacturer Defect to Me!
Old Sep 2, 2009 | 05:40 PM
tim788's Avatar
take it to the dealership.....there is a reflash that will fix this problem.
Old Mar 1, 2010 | 02:18 PM
08EVOVA's Avatar
that code popped up for me as well, if I dont get it reflashed will it hurt my engine?
Old Mar 1, 2010 | 02:33 PM
dek0026's Avatar
Old Mar 2, 2010 | 08:02 AM
tim788's Avatar
you have a tune and still have this problem? your ignition settings never got changed i guess
Old Mar 2, 2010 | 08:53 AM
08EVOVA's Avatar
I'm not sure if they were or not, I was thinking about taking it to mitsubishi to see if they can reflash it with the update but I dont want to be running lean all the way back to my tuner
dragon831
Feb 15, 2009 08:57 PM
jeffreyinigo
Apr 7, 2007 12:42 AM
Lt. Boomstick
May 18, 2006 10:11 AM
rcheung
May 29, 2005 10:16 AM
BostonLancer
Lancer Troubleshooting
Apr 17, 2003 02:33 PM
