Service Engine Soon Light
Old Aug 2, 2009 | 07:19 PM
sQuid^'s Avatar
I have a stock evo x. It has a drop in K&N air filter.
Today I start it up, and the service engine light turns on. I have had this happen before: The reflashes, a bad MAF.
The car seemed to be running fine. I disconnected the battery and reconnected it, and it has stayed off so far...
Has anyone else had this happen, and disconnecting the battery fix it? Maybe the computer just needed a kick in the butt?
Thanks,
Isaac
Old Aug 2, 2009 | 07:47 PM
JoeyM3's Avatar
resetting the ecu will clear the code. you should have pulled the code so you know what code you are throwing. make sure your gas cap is closed all the way.
Old Aug 2, 2009 | 08:21 PM
ILowNslowI's Avatar
mines on too...but then again i have no cat either!
Old Aug 5, 2009 | 11:06 PM
hyprlan's Avatar
^I'm running the UR TP and haven't had the SES light come on for that issue...but it has been popping up P0171(system too lean)....even with the reflash.
Old Aug 6, 2009 | 04:33 AM
4080wrx's Avatar
Are you throwing a service engine light or check engine light? there is a difference, please clarify.
Old Aug 6, 2009 | 05:47 AM
sQuid^'s Avatar
I got it back from the dealer after the light went on again, and the code is P1320. They didnt really say what caused it, only that they would flash it with the newest software (which it had), and see how it goes.
Bah!!!
Old Aug 6, 2009 | 08:12 AM
RedlineX79's Avatar
Unless I am mistaken that is a timing retard insufficient. It can be any number of things from a bad batch of gas to funky a/f ratios. I have heard around here that there is a reflash Mitsu can do that corrects it if it is indeed an issue with the car which it most likely is because this has been happing to more and more people. I have it myself and am going in next Friday to have them look.
Old Aug 6, 2009 | 12:56 PM
jazket's Avatar
Bah!!!
you couldve had AutoZone read the code and find out what it was :-/
u gonna let the dealer flash your car after you reflashed it?
Old Aug 7, 2009 | 05:33 AM
sQuid^'s Avatar
They reflashed it with the same flash it had before. So I guess they dont really know what caused the SES light to come on.
Old Aug 7, 2009 | 10:27 AM
tim788's Avatar
mine came on this morning randomly. the car only has 3500 miles on it and its running just fine but im takin it in this weekend. ill let you know whats up....
Old Aug 7, 2009 | 10:31 AM
cheb evo's Avatar
Disconnecting the battery doesn't truly reset the ECU, the code is still there. You would need to pull the code and erase it to get rid of it.
Old Aug 7, 2009 | 10:48 AM
EvoX777's Avatar
How long ago did you replace the stocl filter with the K&N? It could be the oil from the filter causing you to through a code for the maf.
Old Aug 7, 2009 | 10:57 AM
supergengo's Avatar
I know the OP is in NM, but for CA guys, Autozone no longer lends scanners for free in California.
Old Aug 7, 2009 | 11:09 AM
supergengo's Avatar
I thought so too, but actually the manual refers to them as the same thing. See page 1 in quick index section of the manual.
The other indicator (pic of a wrench) includes the text "Periodic Inspection" and is referred to as the "Service Reminder" (manual pg. 3-154)
Old Aug 7, 2009 | 01:19 PM
JAMiLiTUDE's Avatar
Happened to me also around same milleage. Check engine light came on and idle stood at 2500rpms. Went to the dealership and they replaced the MAF. No mods when problem occured.
