Help me tune my evo x
Old Aug 3, 2009 | 12:59 AM
grafix143's Avatar
Dear,
I own 2009 Evo X GSR , non USDM
I installed some parts such as
AMS Dual tip cat back 3"
AMS Test pipe 3"
HKS drop in filter
HKS ssq BOV
and some other like AMS gear bushing and kiddi stuff
so
I recently purchased Cobb AP and it turned out that all maps only working on USDM evo x . And we dont have any local tuner for japans cars around here.
I tried to contact cobb but no answer. i tried to contact some other e-tuners to send me a map but still no response.
I am willing to send my ECU to re flashing or any one can hook me up with Cobb tuner to custom made me a map or somthing
Old Aug 3, 2009 | 03:06 AM
tephra's Avatar
three options:
1) load a USDM rom on and THEN use the AP
2) dump the AP, and get a tactrix cable, ecuflash, evoscan and a wideband and tune it yourself
3) Email tune from one of the great vendors on here - Probably Mellon
Old Aug 3, 2009 | 04:03 AM
grafix143's Avatar
Originally Posted by tephra
three options:
ok , thank you
1) but how can i get LOAD USDM ROM , what tools i need and from where can i get USDM ROM , and can u put back my ROM back ?
2) i know nothing about tune yet , i may think about tactix cable and give it a shot\
3) i wil try to pm him
thank you again
Old Aug 3, 2009 | 04:28 AM
SiC's Avatar
SiC
Don't forget to turn off Lean Spool in the 2009 models, they are all active on these models (JDM, EDM, & NA).
Old Aug 3, 2009 | 04:31 AM
grafix143's Avatar
and what is the lean spool ?
Old Aug 3, 2009 | 04:34 AM
tephra's Avatar
by P-Bit SiC?
Old Aug 3, 2009 | 06:12 AM
SiC's Avatar
SiC
by P-Bit SiC?
Yes, ECU Option Set 3 Bit. 0
With it on, the AFR is around 1.5 AFR leaner than your target when the target value it richer than 13:1.
Old Aug 3, 2009 | 06:17 AM
tephra's Avatar
yeah ok same as CT9A then...
carry on
Old Aug 3, 2009 | 07:21 AM
LaXGSR's Avatar
Just to double check - is lean spool OFF for 2008 USDM GSR's?
Old Aug 3, 2009 | 01:46 PM
Lauren@MellonTuning's Avatar
Email Mellon at Chris@Mellontuning.com .... he can help you out We're finally tuning the EVO X's....he's been tuning a lot of them lately.
Old Aug 3, 2009 | 02:09 PM
SiC's Avatar
SiC
Yes, it is off on the 2008s
