MAF Scaling Table in grams/second
Old Aug 7, 2009 | 01:37 PM
nj1266's Avatar
Question MAF Scaling Table in grams/second
Does anyone have the code for displaying the MAF scaling table in grams/second instead of HZ?
If you have it, could you post the full code please?
Old Aug 10, 2009 | 05:09 AM
xPRimNT's Avatar
I'll get it up in a couple hours. I need my home computer.
Old Aug 10, 2009 | 05:18 AM
xPRimNT's Avatar
Ok, nevermind. I had it with me. Weird.
Just as a heads up, I was having difficulty with this. I thought the addresses might even be incorrect, but I added the addresses tephra gave (in Hz) and changing either table changes the others, so it must be right. Just give it a try before tuning a crapload of different cars
Evo10base.xml
Code:
    <scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="5" inc="1" storagetype="uint16" endian="big"/>
    <table name="MAF Compensation" category="Fuel" type="2D" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="40" scaling="MAFVoltScaling"/>
    </table>
    <table name="MAF Compensation #2" category="Fuel" type="2D" level="1" scaling="AirFlow16">
    </table>
    <table name="MAF Compensation #3" category="Fuel" type="2D" level="1" scaling="AirFlow16">
        <table name="X" type="X Axis" elements="50" scaling="MAFVoltScaling"/>
    </table>
52680015.xml
Code:
    <table name="MAF Compensation" address="5753a">
        <table name="X" address="615ea"/>
    </table>
    <table name="MAF Compensation #2" address="5758a">
        <table name="X" address="6163a"/>
    </table>
    <table name="MAF Compensation #3" address="575da">
        <table name="X" address="6168a"/>
    </table>
Old Aug 10, 2009 | 05:29 AM
SiC's Avatar
SiC
The EvoX seems to dislike alot of intakes unless you scale the MAF correctly.
Increasing the scaling 10% for the AMS intake worked well for me
Old Aug 10, 2009 | 12:48 PM
nj1266's Avatar
Yes, on the Evo X the trims drift positive with an intake. So you added 10% to the MAF scaling to bring the fuel trims down to about 0%, assuming that the AMS intake was causing your LTFT cruise to go positive by 10%.
My question is: What section of the MAF scaling did you add the 10% to? The entire scale or from 40 to 100 g/s? 40-100 being the area that you will be in when cruising.
Old Aug 10, 2009 | 12:52 PM
nj1266's Avatar
I looked up the code that Tepra gave in HZ and your code in g/s and the addresses are different. I have no idea which one is the correct one:
Here is Tephra's
Add to 5268xxx.xml
<table name="MAF Scaling Part 1" address="5753a">
<table name="Volts" address="615ea"/>
</table>
<table name="MAF Scaling Part 2" address="57592">
<table name="Volts" address="61642"/>
</table>
<table name="MAF Scaling Part 3" address="575ea">
<table name="Volts" address="6169a"/>
</table>
And here is yours:
Add to 52680015.xml
</table>
<table name="Volts" address="6163a"/>
</table>
<table name="Volts" address="6168a"/>
</table>
Old Aug 10, 2009 | 02:09 PM
SiC's Avatar
SiC
I actually did the entire range, I've seen some that actually start off at 10% and end up going to around 20% at 5v.
Old Aug 10, 2009 | 02:44 PM
nj1266's Avatar
Interesting that they do that.
From my understanding changing the g/s values is directly related to the changes in your trims. So if your LTFT cruise is +10, then you INCREASE the g/s values in the 40-100 range by 10%. If the LTFT cruise is -10%, the you DECREASE g/s values in the 40-100 range by 10%.
I do not know why they add more as the voltage increases. It does not make sense to me.
Old Aug 10, 2009 | 02:48 PM
xPRimNT's Avatar
I know the addresses are different. That's what I was getting at.
However, changing one changes the other, so I don't know what the right way to do it is.
Old Aug 10, 2009 | 02:54 PM
SiC's Avatar
SiC
I've heard of multiple ways to do this, AMS actually told me to change the idle and 3.0v to 5.0v range.
Cobb has theirs set to taper upwards like I mentioned earlier.
I just went ahead and did +10% in the entire range, so far no side effects.
Old Aug 10, 2009 | 05:18 PM
tephra's Avatar
the addresses are different because the number of elements are probably different.
also doesn't calculating g/s requires temp input?
Old Aug 10, 2009 | 07:01 PM
nj1266's Avatar
So it is not possible to display the MAF scaling tables in g/s?
If it is possible, can provide us with the code so we can add it to the USDM xml files?
Old Aug 10, 2009 | 08:32 PM
SiC's Avatar
SiC
The code xPRimNT posted above is the MAF Scaling in g/s. You can tell since it uses AirFlow16 as the scaling.
Old Aug 10, 2009 | 09:40 PM
nj1266's Avatar
What about the difference in addresses between what xPRimNT provided and what Tephra provided? Which ones do we use?
Old Aug 10, 2009 | 09:50 PM
tephra's Avatar
as I have said 3 times now - you will need to look at the number of elements in the xml and work out which one is correct... AFAIK what I posted is right (as long as your using the evo10base.xml segment i posted too)
