Low Timing and hesitation during cold start
Old Nov 2, 2009 | 10:08 PM
  #46
Clipse3GT's Avatar
Bump.... hmm I will be trying this out today
Get rid of some of the cold start problems...
Old May 12, 2010 | 08:42 AM
  #47
fostytou's Avatar
EvoM Community Team
Originally Posted by tephra
yeah I am not 100% sure..
52680015:
<table name="Percent Low Temp Timing Trim vs Coolant Temp" address="56170">
<table name="Engine Temp" address="610e0"/>
</table>
Sorry to bring this back from the dead.
I'm running 52680020. My car came with 52680015 and had these values:
Code:
-32	0
-8	100
7	100
20	100
34	100
50	0
62	0
77	0
I got an what I assumed was a factory 52680020 ROM from my roommate, and a little while ago I changed these values to this just to help a bit with cold running.
Code:
-32	0
-8	70.1961
7	70.1961
20	50.1961
34	25.098
50	0
62	0
77	0
I just switched to e85 and would get a slight hesitation on warmup, so I went to pull things back drastically for this fuel. I set the table to this:
Code:
-32	0
-8	50.1961
7	25.098
20	0
34	0
50	0
62	0
77	0
The car nearly died after starting, and would roll from rich to very lean. Any gas was VERY lean and the idle was very rough. I tried to get about a block and decided to swap this map back to what I had it at... no problems.
1) Does this have the same function / is the definition correct in 52680020?
2) This reminds me of a common problem on the CT9A. Is it possible that the same thing is happening there?
Old May 19, 2010 | 09:00 AM
  #48
fostytou's Avatar
EvoM Community Team
*Nudge*... can anyone try this for me or look at the code and see whats going on? Also, is this actually a retard of the timing, an advancement of it, or simply a set value (thereby retarding)? I ask because the degrees are positive and the car definitely seems to gather itself right after the transition from 3->5. I've also read that increased timing can lead to high EGT's, which could also accomplish the goal of warming up the cat (but is semi-contradictory to general tuning practices for cold conditions).
I assume it is not a set value but I need to log, however this would explain the major difference when the car hits the transition area. Its not stumbling here with the closer to stock values, but it hesitates and needs alot of throttle to go anywhere.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Appauldd
Sep 21, 2015 08:39 AM
211Ratsbud
Jun 21, 2013 05:21 PM
