low gear boost...
Old Aug 28, 2009 | 08:24 PM
GTR2009's Avatar
low gear boost...
How much boost do you get guys on lower gears ? in 1st, 2nd, 3rd gears? on Evo X with stock turbo.
Old Aug 29, 2009 | 12:30 AM
BigT's Avatar
I think I hit 25 in first gear, but the rest of the gears are around 27psi.
Old Aug 29, 2009 | 03:54 AM
GTR2009's Avatar
wow ! and the transmission can hold launches with 25psi in first gear ?
I have 26-27psi in 5th gear and 24psi in 4th, lower gears are under 20psi.
Do you have a 3 port solenoid or boost controller?
Old Aug 29, 2009 | 02:17 PM
BigT's Avatar
Stock setup with GST boost pill upgrade. Umm, I don't launch at 25psi. I build like 3-5psi with the launch control. Thats plenty on the stock turbo.
Old Aug 29, 2009 | 08:05 PM
GTR2009's Avatar
You have 3-5psi in launch RPM, but when you lift the clutch in less than 1 second you have a lot off boost which makes an extreme stress on transmission
Old Aug 29, 2009 | 09:33 PM
tephra's Avatar
pfft... its a 5 speed...
Old Aug 30, 2009 | 02:52 AM
BigT's Avatar
I know.
I love how torquie this car feels for a 2.0L turbo 4 cylinder.
The stress is more on the clutch until you start making big big power. I doubt the stock turbo can stress the tranny even when maxed out. Of course, this is with proper driving and operation.
I'll stress it out some more as soon as Tephra can give us an NLTS patch.
pretty pretty please!
