AMS 02 Sensor spacer
Old Sep 4, 2009 | 01:47 PM
niminuh's Avatar
Anyone know how to install this thing?
It looks pretty straight forward, but I don;'t understand what these three metalic item or that rubber horseshoe is there for.
Answers?
Old Sep 5, 2009 | 06:04 AM
DarwinX's Avatar
Maybe this picture will help...
As for the three different restrictors & lock ring you received with the O2 spacer, try the middle size one first and secure it with the lock ring inside the spacer. after that it's just a matter of installing the O2 spacer into your pipe, then installing the O2 sensor itself into the spacer (don't forget to use some anti-sieze for this). If you end up getting a CEL even after installing the O2 spacer, you may have to remove it and try one of the other sized restrictors.
Old Sep 6, 2009 | 11:37 AM
niminuh's Avatar
Your awesome, thanks I'll give it a whirl in the next few days.
Old Sep 6, 2009 | 01:08 PM
chapscalyx's Avatar
i'm using the smallest restrictor now. had for 2 days w/o a cell. i'm using ams hfc
Old Sep 6, 2009 | 08:29 PM
niminuh's Avatar
Running the exact same, we'll see who's light pops on first!
Old Sep 26, 2009 | 02:18 AM
WickedEX's Avatar
using the mid sized restrictor, no CEL so far.
Old Sep 26, 2009 | 01:01 PM
Bob Evolved's Avatar
ive had the smallest restrictor in for about 2 months with no cel
Old Sep 26, 2009 | 01:11 PM
XxLaNcErGTSxX's Avatar
I have the AMS downpipe and the AMS HFC. Put the spacer on the HFC and the CEL came on. DO I need to put 1 on the downpipe?
Old Sep 26, 2009 | 01:16 PM
EndlessRed's Avatar
make sure you clear the cel first.
if it still comes on use a different spacer.
Old Sep 26, 2009 | 01:17 PM
JEP's Avatar
JEP
Guys On AMS website it show a pic of the spacer. Isn't the spacer just a 2 or 3 dollar antifouler? If it is seems like 25 dollars is a little much!!!
Old Sep 26, 2009 | 01:25 PM
I did clear it and then put it on. Im using the smallest 1
Old Sep 26, 2009 | 05:40 PM
NSS's Avatar
NSS
did it work
Old Sep 26, 2009 | 05:59 PM
EndlessRed's Avatar
you're right. it's exactly what it is.
and you're right, it is a bit much. i'd opt for the touge factory L type...but i wasn't smart enough back then.
Old Sep 26, 2009 | 06:07 PM
Originally Posted by NSS
did it work
no the light is still on. do i need to put 1 on the downpipe?
Old Sep 26, 2009 | 06:14 PM
EndlessRed's Avatar
no; putting it on the downpipe has no effect whatsoever.
