Speed density
Old Oct 2, 2009 | 10:33 AM
GUM EVO X's Avatar
Speed density
Any progress or talk of speed density on the stock ecu yet? The MAF has become a pain in the **** now that my car is forged running high boost and aftermarket turbo.
Kind regards,
GUM
Old Oct 2, 2009 | 01:17 PM
derekste's Avatar
No. I think SD on the 8/9 is still in the experimental stage, so I wouldn't hold my breath. Stock ECU should be good for over 500whp (as it is on the 8/9), however I don't know how far along we are on modifying knock maps like people on 8/9s are. I imagine being built and getting phantom knock is your biggest hurdle right now? Maf scaling should be easy to handle. Alternatively, you could get a larger MAF housing and retune on that.
Old Oct 2, 2009 | 07:37 PM
drewgray's Avatar
SD has more advantages than what you are thinking. I, too, hope that tephra or JB or whomever will help to transition the SD to an evo X as well. I would change to it as soon as it was released.
tephra's Avatar
knock arrangement is 95% the same as 7/8/9
so if your getting phantom knock we can solve that.
Old Oct 5, 2009 | 08:45 PM
GUM EVO X's Avatar
Hello again,
Yes I have adjusted the knock sensitivity using ecutek, however have chewed up my second MAF and its becoming a pain in the ***. Also my tuner would like to run MAF less in an ideal world... so nothing is available in the states? I am using a HKS induction kit and am thinking maybe i need to go even bigger with the MAF housing???
Kind regards,
GUM
Old Apr 23, 2010 | 01:43 PM
tyflip2's Avatar
Is there any new progression with speed density on the evo X stock ECU?
Old Jul 18, 2010 | 05:43 PM
Guru's Avatar
Tephra? Any word on if it will be easy to do?
Old Jul 19, 2010 | 09:55 AM
BCOZEVO's Avatar
One word
MAFT!
I used it on my DSM, I used it on my IX now I am using it on my X.
Sometimes the classics still sound best
Yiyo
Northeast Region
10
Jan 15, 2013 05:42 AM
evo1008
Oct 11, 2011 11:05 AM
zeroth3rm
Jun 19, 2006 08:44 PM
Juiced
Feb 28, 2006 07:12 PM
