ecuFlash noob questions
Old Oct 6, 2009 | 06:19 PM
boostin20's Avatar
Let me start out by saying I've been reading so much it's been making my head spin. I've also gone through every X ecuflash thread I can find. I went through the beginner threads and ecuflash for dummies, etc and kept noticing a constant for the older evos. They all say to get the immobilizer code and put it in the new rom before writing the ecu. Is that something that is for the X as well? If so, can someone give me some direct info on where to pull and insert that code?
Also, I noticed people are modifying .xml's for mode 23, etc. I tried opening a rom with my .hex reader and it came out like the attached pic below. WTF? I also tried .xml editor I downloaded and notepad. Still, WTF. They all came up only crazy symbols. Can someone help me out with this?
Attached Thumbnails ecuFlash noob questions-wtf.jpg   ecuFlash noob questions-wtf1.jpg
Old Oct 6, 2009 | 06:20 PM
Bergen Automotive's Avatar
images FAIL
Old Oct 6, 2009 | 06:21 PM
boostin20's Avatar
Not anymore
Old Oct 6, 2009 | 07:45 PM
xPRimNT's Avatar
Boostin, no need for immobilizer copying on the X.
When you want to modify xml's, it has nothing to do with your ROM file. What you do is add information to ECUFlash's xml, so that it will allow you to change the ROM from within ECUFlash. You basically open up the ECUFlash program folder, find rommetadata, look for mitsu and evo, then you edit the appropriate xmls.
Old Oct 6, 2009 | 08:28 PM
boostin20's Avatar
Thanks, and I found how to modify the definitions. New problem now, I try to load a rom image I have saved and every time it says unknown rom. I read the openecu forums and it said to go to file>options>rom file directory and set to ecuflash\rommetdata which you can see in first pic below. Then I try to open my saved rom and I get the unknown rom image in the second pic. I've also uninstalled and reinstalled 3 times with no luck. Any suggestions on how to fix this?
Attached Thumbnails ecuFlash noob questions-rom-file-dir.jpg   ecuFlash noob questions-rom-image.jpg
Old Oct 6, 2009 | 08:36 PM
xPRimNT's Avatar
What ROM are you trying to open? Is it actually a legitimate ROM?
Old Oct 6, 2009 | 08:40 PM
boostin20's Avatar
They are, I will pm you because it's a link from another forum
20psiMR
Feb 25, 2018 08:03 PM
Thoe99
Nov 13, 2010 06:30 AM
is300
Nov 2, 2009 06:29 AM
sgand
Lancer Troubleshooting
May 15, 2008 08:13 PM
vegasboy301
Jul 26, 2005 02:05 AM
