Need help / suggestion
Old Nov 1, 2009 | 08:14 AM
Pat031's Avatar
Originally Posted by H Jensen
To me it looks like your timing is advanced to much where your getting knock, i'd back it up a degree at a time in that load range until it goes away. That knock was probably amplified last time.
I will be able to gather more data today. It's 6 Celius at the moment so I expect to be able to replicate the problem.
I do not think that my problem is a knock. It really feel like I hit a brick wall when it happend.
I find out that my boost should be around 20 mmhg vacuum so that explain why my sensor read around -10 psi in mode23.
Regards,
Old Nov 1, 2009 | 04:10 PM
Pat031's Avatar
Hi there,
Finnaly I was able to record the problem.
Like previous people mention, that was an over boost issue
You can see on the graph the detail and a correction that I propose.
Please tell me if I'm on the correct path or I chould change something else
Regards,
Old Nov 2, 2009 | 05:23 AM
Pat031's Avatar
bump!
