Help P0107
Old Nov 6, 2009 | 08:13 AM
Yousef's Avatar
Help P0107
P0107 BARO sensor circuit out of range low
500 meters away from home the evo suddenly got into limp mode and shutdown with steering lock
off-on many times code is gone and car is normal, drove her home and shes parked since then!!!!!
what the hell does that mean??? what is BARO??
I had nothing but problems with this car !!!!!!!!! i am so mad
Old Nov 6, 2009 | 08:59 AM
Clipse3GT's Avatar
Probably a vacuum leak or boost leak.
I suggest you check the FPR vacuum line to see if it didn't pop off.
Old Nov 6, 2009 | 09:08 AM
Clipse3GT's Avatar
Brain storm...
Abu dhabi is almost at sea level maybe a bit above or below sea level.
The sensor reads 0-1800 meters. If you go below 0 or below sea level for over 2 min you might throw the code.
I say reset your ECU and check the FPR line.
Go and drive and see if you can repeat the condition.
Old Nov 6, 2009 | 10:48 AM
Yousef's Avatar
where is the FPR vacuum line?
thanx
Old Nov 6, 2009 | 11:27 AM
AWDTerror's Avatar
thanx
it's the one that pops off the intake manifold. it right near the oil dipstick.
Old Nov 6, 2009 | 12:02 PM
Yousef's Avatar
checked all visible vacuum lines
took her for a hard short test drive, all good !!!!!!
this car is driving me crazy
I have a 350 miles trip next week :s
Old Nov 6, 2009 | 02:48 PM
AWDTerror's Avatar
P107 deals with the MAP sensor....sounds like just a fluke code
http://www.obd-codes.com/p0107
Old Nov 6, 2009 | 04:48 PM
Clipse3GT's Avatar
Bet you it went of becaue you are so close to sea level, which is 0. Baro went for a wacky reading.
Old Nov 6, 2009 | 05:30 PM
stikllr13's Avatar
^^ I dont know about that. Several areas in the united states and other places are below sea level. The MAP sensor doesn't necessarily read altitude. It measures the BAROmetric pressure of the atmosphere to determine the density of the air. My guess to the OP's problem is that he might have a intermittent vacuum leak near the MAP sensor.
But since this only happened once and you can't repeat the problem then it could be a weak connection at a connector or high resistance in the circuit.
Let us know what you find, I suggest you take it to a shop and try to have this diagnosed
jerrymldz
Jun 16, 2017 02:40 PM
upcom'n_meknk
Lancer Troubleshooting
May 15, 2017 12:31 PM
heliarcpro
Mar 24, 2016 06:39 AM
black_beauty
Aug 12, 2011 05:18 PM
EvoSeanzie
Jun 20, 2010 06:18 PM
