Following a trend... ECU Bricked...
Old Nov 25, 2009 | 09:18 PM
Clipse3GT's Avatar
Yup, following the recent thread. ECUFLASH decided to go blue screen on me DURING a flash. I tried to do exit programing state while still on, did nothing. I tried flash while still on did nothing. I tried resetting the battery did nothing, ofcourse. When I turn the key to the ON position fans kick. Meaning it is still in PROGRAMMING STATE. Took to the ECU out to BENCH it.
Following these guidelines.
Code:
If it don't work then:
1) When a flash craps out half way through:
a) DO NOT TURN THE CAR OFF
b) YOU CAN RESTART THE LAPTOP
c) TRY REFLASHING
2) If you did a) above then (until Colby fixes the inbuilt recovery mode) you need to bench your ECU - Basically:
Use http://www.roadraceengineering.com/e...-ecuwiring.htm as a reference
Looks like you need to hook up:
Power/Grounds:
73 = +12v?
81 = ground
82 = +12v?
93 = ground
104 = +12v?
Just ensure the "power pins" have +12v and the continutity between the ground pins and chassis is 0ohms:
To OBD connector:
90 = CANH
91 = CANL
80 = Kline
103 = pin 8 or 12 ???
If in doubt I would start by measuring the voltage output on the pins you will be "emulating". And also measuring the continuity between the OBD and ECU harness for the OBD connections.
A friend has done this and was able to recover their ECU
Code:
Pin 8 or 12 on the obd plug IS NOT connected to pin 103 on the ecu which is the reflash pin. i had this problem on my ecu so i had to send it to Colby (all the way from New Zealand). follow the above instructions from tephra, that should fix your problem.
I tried combinations of 8 + 12 connected to 103. 103 + 12 and 103+ 8 and just 8 +12 connected. Each time I try I get a message stating:
Kernel Get Version
Interface Close
I am at the end of my mind trying to bench this anyone else want to chip in. Maybe I am missing a step or something? Go figure it has to happens on Thanksgiving....
Old Nov 25, 2009 | 10:17 PM
tephra's Avatar
i'll ask my friend what he did...
when it blue screened - did you reboot your laptop and then retry the flash?
keeping the car ign on the whole time?
from the diagram I have - pin8 on the OBD connector should connect to pin 103 on the ECU
Old Nov 25, 2009 | 10:32 PM
FTY Motorsports's Avatar
lol i gave up trying to bench myself im sending it in to tactrix lol its only 75 bucks man
Old Nov 26, 2009 | 07:39 AM
Clipse3GT's Avatar
Thanks I appreciate it. I will try again redoing a flash maybe it will go. I will recheck today. If not I will have to send it to COLBY.
I think I am missing a step somewhere... since sometimes I will get the ECU to read my HW Version and ECU HW # and then start to continue but then it says "interface closed" and stop there. So it's like almost working, but just not all there.
Clipse3GT's Avatar
Can you PM me his info?
Old Nov 26, 2009 | 09:03 AM
Clipse3GT's Avatar
So this is what I get from the log.
As far I get on the bench...
[12:00:58.720] J2534 API Version: 04.04
[12:00:58.720] J2534 DLL Version: 0.50.2598 (DEBUG) Jun 26 2009 15:02:29
[12:00:58.720] Device Firmware Version: 1.10.2658
[12:00:58.932] -- loading kernel --
[12:00:58.932] -- connecting to kernel --
[12:00:58.932] kernel get version
[12:00:59.306] ECU HW part number : 1860A978
[12:00:59.330] ECU SW part number : 1860A97903
[12:00:59.349] -- unlocking ECU --
[12:00:59.349] starting session...
[12:00:59.365] requesting seed...
[12:00:59.388] sending key...
[12:00:59.916] interface close
[12:00:59.927] interface close
Old Nov 26, 2009 | 10:11 AM
palmerblock's Avatar
my did the blue screen of death the other day during a read, and i simply restarted it and it connected back with no problems.....weird
Old Nov 26, 2009 | 10:57 AM
Clipse3GT's Avatar
Mine was during a write. Not a read. That's the problem
Old Nov 26, 2009 | 11:14 AM
you get further than i do mine stops at kernel read interface closed lol just go on tactrix website its right there.
http://www.tactrix.com/product_info....products_id=50
Old Nov 26, 2009 | 01:03 PM
Clipse3GT's Avatar
Thanks mate!
I will overnite/same day it to him.
We really need to figure out how to bench the ECU properly.
There is probably a extra step we are missing form the recipe we have up top.
There is probably a jumper configuration that switches it out of program state or you have to flip a DIP switch in the ECU.
Old Nov 26, 2009 | 01:04 PM
HB Speed's Avatar
That wont matter. You just have to keep trying (if you haven't turned the key off)
Old Nov 26, 2009 | 01:05 PM
HB Speed's Avatar
What about the one i unbricked for you ?
Old Nov 26, 2009 | 02:38 PM
SiC's Avatar
SiC
Would be nice if someone can do an idiot proof write up with pics on how to unbrick an ECU on a bench
Old Nov 26, 2009 | 03:48 PM
tephra's Avatar
yeah i'm waiting for my friend to get back to me.
he said my wiring was almost correct, just had to hook up a few more as well..
Old Nov 27, 2009 | 06:36 AM
Clipse3GT's Avatar
ahhh... there you go
