Unstable idle
Old Dec 10, 2009 | 12:02 AM
xhomm02's Avatar
Originally Posted by xhomm02
WTF - today I got CELs:
1) cylinder 2 misfire
2) O2 sensor #1 no activity
After clearing them they did not come again - could the problem be O2 giving wrong signal?
Why does it work fine (stable idle 1000rpm) when I disconnect MAF?
One more thing I have noticed - the timing advance during the f.....g idle jumps from 5 - 20 degrees, even if according to timing map it should be (in that rpm and load) 10degrees. Is the idle timing influenced by any ather "timing correction" map?
Old Dec 10, 2009 | 12:19 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Can you post log?
Old Dec 10, 2009 | 06:58 AM
xhomm02's Avatar
Originally Posted by acamus
Can you post log?
****... I wanted to make the log and the car runs fine all the day... Really strange.
Old Dec 10, 2009 | 08:01 AM
atombomb33's Avatar
EvoM Community Team
You need to talk to your tuner.
Old Dec 12, 2009 | 11:29 AM
xhomm02's Avatar
Please take a look at the log (both situations a few minutes one from other):
I marked blue normal idle. Marked with orange there it is very unstable, with rpm fluctuating between 400 and 800. If you take a look at the STFT, could it be caused by O2 sensor reading bad and leanig out the idle making it unstabe?
File Type: zip
rich3389
Sep 8, 2024 07:27 AM
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
hurdle18
Feb 23, 2015 07:26 AM
ittick
Lancer Troubleshooting
Jul 16, 2013 08:58 PM
fengzhaoxi
Apr 3, 2010 10:54 PM
