ECUFLASH: Reactive Solenoid Maps: When do they interpolate?
Old Dec 21, 2010 | 10:13 PM
RazorLab's Avatar
Originally Posted by Jumperalex
Bringing this post back from the dead ... can anyone tell me why my stock 2010 X SE would have the Xover set at 161? I mean dang that means I am not even using my low gear maps :O
EDIT: Leaving the above for posterity ... beyond that, never mind, I see what is happening now and what Gunzo is doing with his boost maps.
It's set to use different boost between first and second, however the actual boost maps themselves are not. The 2008 MR did however in one of the first ROM ID's.
161 is right between 1st and 2nd in the MR
The altitude thing is a rumor. My RA uses the different maps depending on crossover at sea level and 7000 feet. Yes, tested.
Old Dec 22, 2010 | 12:33 AM
kozmic27's Avatar
Because the SE is really an MR in disguise. So the crossover point is higher.
In OEM form, map 1b is 5th gear on a gsr, and 6th gear in an SST car.
In OEM form maps 2 (low gear) are first gear.
Old Dec 22, 2010 | 05:40 AM
Jumperalex's Avatar
Yup I think I got it it now. What threw me for a loop was looking at Gunzo's MR map and seeing a crossover of 60. I guess im still left wondering if I don't want to keep first gear as low only vice first thru third because first is sooo low of a gear it can be hard to control when not doing a wot run. But im also considering playing with the slope of the table that is also based on TPS to give me even less boost at part throttle.
Old Dec 22, 2010 | 05:42 AM
Jumperalex's Avatar
Control in this case means not leaping off the line and heading towards redline when I just want a crisp pull away from a light. Right now it is like I have two choices creep or fly
tephra
Sep 13, 2021 01:07 AM
TheIndianGuy
Apr 11, 2017 09:44 PM
richardjh
21
Aug 23, 2012 12:05 AM
Piper747
Oct 9, 2010 01:14 PM
crimson red
Sep 8, 2010 06:14 AM
