What do you guys think of my tune ?
Old Jan 10, 2010 | 03:38 AM
E6-X's Avatar
Hi Guys,
Did some on the road tuning today and here are the logs.
It's not perfect but i did some touch ups.
1st log is 3rd gear pull & 2nd log is 4th gear pull.
All comments, suggestions, advise & etc are welcomed
Opppssss ... here are my mods,
HKS Reloaded Suction Intake
AMS High Flow Cat
HKS Center pipe
HKS Legamax
HKS IC Pipes
Ecuflash self-tuned with LC1 XD16 combo
Everything else is stock
Old Jan 10, 2010 | 05:46 AM
vetboss's Avatar
Originally Posted by E6-X
...Did some on the road tuning today and here are the logs.
No logs attached, unless I missed them
Old Jan 10, 2010 | 06:16 AM
penthouse's Avatar
without the intercooler and boost controller i said he's making around 300whp on dynojet
Old Jan 10, 2010 | 07:48 AM
E6-X's Avatar
sorry forgot to attach
here it is 1st is 3rd gear pull & 2nd is 4th gear pull
here's the image ... BIG THX to Gunzo for generating image
is it normal that my TPS is at 86-87.xx during WOT ?
thx
Old Jan 10, 2010 | 10:44 AM
penthouse's Avatar
i knew u were around 300 whp, but at 6500rpm, your graph look kinda weird. Is the car feel pretty smooth all the way redline?
Old Jan 10, 2010 | 10:55 AM
E6-X's Avatar
you're spot on mate, as i do not have access to a dyno where i'm at but pretty happy with the results by tuning on the road (4th gear pull was interesting)
yep, it's smoother now, did some minor tweaks, smoothen out the afr, boost & timing.
might have a few more ponies now i think with better timing & afr.
looking forward to upgrade 3port+WGA for better boost control & FMIC for better flow & cooler air.
how much do you think i can gain from those 2 add-ons ? 10/20/30 whp ?
Old Jan 10, 2010 | 11:15 AM
penthouse's Avatar
here is my mods on my 08 X gsr: ams fmic with upper , lower ic pipes, intake. greddy new dual outlet catback, tsubo testpipe, stock dowpipe, greddy profec2 boostcontrol, hks bov. Just tuned at 25psi on dynojet making around 350whp, 350 torgue. My tuner said the fmic help a lot.
Old Jan 10, 2010 | 09:40 PM
E6-X's Avatar
that's good power you're making. i hope i can get near to your no's but i doubt so cos of the 91 oct gas
Old Jan 15, 2010 | 07:39 PM
yorT's Avatar
Hey took your number from your 3rd gear run and found your volumetric eff., Mass Air flow, and Mass fuel flow. Don't mind the column about hp, I don't think I did that right. You got good Vol Eff.
File Type: zip
