really bad knock all of a sudden
Old Feb 12, 2010 | 05:57 PM
  #256
tephra's Avatar
thats very interesting, and would explain why a certain persons ROM I saw recently had 8* at peak torque, BUT also had 50*+ of cam overlap at peak torque as well... I wonder if this affect is allowing them to run 8*
hrmm very interesting! i like this theory hehe
so basically if the HFC has cleared the exhaust restriction then iEGR is no longer taking affect, so my cylinder temps have gone up, and thus my knock resistance has gone down.
so to fix, either:
1) reduce timing
2) retard exhaust CAM MORE, so that more exhaust can enter.
but really iEGR is NOT what you want, so number 2 is OUT, so reducing timing is the better thing todo..
edit - i would have thought that HOT exhaust gases being injected back to the cylinder would have made the mixture more pre-ignition prone?
Old Feb 12, 2010 | 06:22 PM
  #257
tephra's Avatar
and I should be able to prove this theory by reducing the retard on my exhaust CAM. to simulate a clearer exhaust?
Old Feb 12, 2010 | 06:34 PM
  #258
SiC's Avatar
SiC
Yes reduction of the exhaust retard
Old Feb 13, 2010 | 07:26 AM
  #259
BigT's Avatar
Tephra, have you tested with less exhaust retard yet?
Old Feb 13, 2010 | 07:37 AM
  #260
Clipse3GT's Avatar
Originally Posted by criptballer
Add New Item
Enter in these parameters... Presto...
Old Feb 14, 2010 | 03:12 AM
  #261
tephra's Avatar
I retarded the exhaust cam slightly, but it didn't really do much...
I did about 6 pulls today and no knock, i have been leaning out the map to 11.7 as well..
so yeah i'll do some more testing then put the cat back in...
bizzare!
Old Feb 14, 2010 | 03:14 AM
  #262
BigT's Avatar
bizzare!
So, its almost back to normal now? What changes were made since it started knocking?
Old Feb 14, 2010 | 03:16 AM
  #263
tephra's Avatar
seems that way...
well i have added 1/4 point of fuel in the 3000rpm column, during spool mainly.
but leaned out the rest of the map a bit...
i will get a new decent log and post it up tommorow...
i dunno, i prefer to have a proper resolution to the problem
Old Feb 14, 2010 | 03:23 AM
  #264
BigT's Avatar
seems that way...
So spool-up is a little richer now. I can understand wanting a proper resolution as most of us should. I'm still worried about the exhaust mivec being so slow.
Old Feb 14, 2010 | 04:21 AM
  #265
tephra's Avatar
have you logged your car for MIVEC?
Old Feb 14, 2010 | 04:25 AM
  #266
BigT's Avatar
I haven't had a chance to run out and log the car, but I will shortly.
Old Feb 15, 2010 | 03:47 AM
  #267
tephra's Avatar
maybe we should make a new thread, about MIVEC lag, and get some results from different mods (like stock vs exhaust vs oils etc) to see if there is a pattern?
Old Feb 15, 2010 | 09:08 PM
  #268
tephra's Avatar
quick question - my brain isn't working today:
if I reduce my exhaust cam retard and my AFR leans out, what does that mean?
can the only conclusion be that I have achieved a greater VE? or is there any other explaination?
Old Feb 15, 2010 | 09:36 PM
  #269
Clipse3GT's Avatar
Something intersting here from my car...
Notice the correlation between target and acutal... MIVEC overshoots the targert...
Causes very lean AFR's, then once MIVEC is stable again AFR's return to normal... or specific values...
I been messing with MIVEC, so the target AFR's are a bit more from the orginal map I had setup. Either way to me it seems that each time MIVEC overshoots the target values the AFR's lean out...
Old Feb 16, 2010 | 01:52 AM
  #270
e_leo's Avatar
You are making more power.I noticed the same on dyno at high rpm.
