E85 conversion question/help
Old Feb 3, 2010 | 06:01 PM
mlomker's Avatar
I haven't had any cold start issues. The torque is addictive. You'll think something is wrong with your car if you switch back...
Old Feb 4, 2010 | 12:25 AM
nlp187's Avatar
Thanks for the input guys. I wouldn't be switching everyday, I know that wouldn't be very good mixing the fuels. I would obviously run the tank dry before switching, maybe after a month or before I go out of town. None the less, I've seen the tq numbers and can only imagine. The idea is still up in the air for me, might go water/meth, e85 looks like the way to go though.
Old Feb 4, 2010 | 01:55 PM
darthvader's Avatar
Cobb accessport
GO WITH COBB AND YOU WILL TRANSITION TO E85 SMOOTHER MAPS ARE ALREADY AVAILABLE JUST CALL THEM AND ASK IF YOU NEED ANY OTHER MODS 800CC MAPS CAN BE DOWNLOADED FROM THE WEBSITE
Old Feb 4, 2010 | 02:24 PM
kozmic27's Avatar
You can run the inline walbro kit in this post to support E85 as well. The inline kit is available seperately, not just as part of the surge tank kit. The inline walbro set up will flow more fuel than an in tank setup would.
https://www.evolutionm.net/forums/ev...-tank-kit.html
