Mivec Setting For Cosworth Cams (stock turbo)
Old Feb 1, 2010 | 08:37 AM
slonez's Avatar
Anyone knows where I can get recommended Mivec setting for the cosworth cams with stock turbo?
Thanks in advance.
Old Feb 1, 2010 | 08:48 AM
murlo26's Avatar
I'd like to help since i run them on the stock turbo but I don't think my settings would apply since I am running E85.
Good luck, hopefully someone can give you a basemap or something. Personally i would go get a tune from a pro unless you are skilled at self tuning. The idle will take a while to dial in.
Old Feb 1, 2010 | 09:08 AM
Clipse3GT's Avatar
I really doubt that MIVEC has anything to do with fuel type.
Old Feb 1, 2010 | 09:15 AM
murlo26's Avatar
I don't see how it wouldn't. I have seen several dyno's where e85 has helped spool turbo's faster which i am guessing has to do with mivec settings and timing not octane rating. I could be wrong.
But like i said even so i wouldn't be able to help much, didn't tune my own car and wouldn't give out mivec settings since they are my tuners maps.
Old Feb 1, 2010 | 09:20 AM
Clipse3GT's Avatar
Then why post?
If in the end you can't help. Makes no sense.
Old Feb 1, 2010 | 09:25 AM
murlo26's Avatar
Then why post?
I gave him my take that he should seek a tuner rather than try to use some other person's mivec maps which odds are will not work.
I was simply stating i would help if i could. You also posted absolutely nothing relevant or helpful...works both ways pal
Old Feb 1, 2010 | 09:40 AM
Clipse3GT's Avatar
I was replying to your post not his...
You were replying to his post.
Old Feb 1, 2010 | 09:41 AM
murlo26's Avatar
This is going no where fast, lol.
Old Feb 1, 2010 | 10:27 AM
rogue's Avatar
You both confused me.
Old Feb 1, 2010 | 10:53 AM
Clipse3GT's Avatar
mission accomplished...
Old Feb 1, 2010 | 11:50 AM
Bugermass's Avatar
E85 spools faster because you burn more of it for a given power level, basically you end up with more exhaust gas per HP than you would with gasoline.
Old Feb 1, 2010 | 11:53 AM
murlo26's Avatar
Makes sense, so i was correct to assume it spools faster and e85 mivec settings should be different, gotcha!
Old Feb 1, 2010 | 12:08 PM
Bugermass's Avatar
Old Feb 1, 2010 | 12:42 PM
GST Motorsports's Avatar
Indeed. I have a bunch of overlays with 20-30whp/20-30wtq gains from just adding E85 and scaling the injectors. Same timing, boost, mivec, etc as 91 pump gas. 93 YMMV.
E85 Army
- Bryan
Old Feb 1, 2010 | 04:47 PM
slonez's Avatar
Just to add, on pump gas.
